HP Pavilion 15-n (U92) not powering on with charger
  • classicandy
    • Apr 2018
    • 308
    • Nigeria
    Hi, Please I have this HP Pavilion 15 (U92) that is not powering On with only the Charger but does power on when the battery is in it.
    I have changed Charging IC [BQ24728] PU2
    I have also replaced PQ21 and PQ15 MOSFET
    Still no solution
  • mobotest
    • Mar 2020
    • 26
    • US
    Re: HP Pavilion 15-n (U92) not powering on with charger
    With only the AC adapter connected, what are the readings on all pins of the Charging IC?
    Upload schematic if you have it.
    • classicandy
      • Apr 2018
      • 308
      • Nigeria
      I have taken the readings of the charging IC [BQ24728] PU2 of a good board and that of the faulty board. Please check the images attached
      When the motherboard is switched off, it charges the battery but immediately i switch on the system (with battery attached), it stops charging...... The AMBER LED turns to WHITE.
      Please I need help with this laptop.... Thanks
      • classicandy
        • Apr 2018
        • 308
        • Nigeria
        here is the schematics
        • mobotest
          • Mar 2020
          • 26
          • US
          My HP laptop (DIFFERENT than your model) had similar symptoms.
          If you want to try something quick for a possible fix, replace PQ20.
          I had parts corresponding to MOSFETS PQ20, PQ21, PQ14, PQ15 and CHARGE IC PU2 replaced on my laptop.
          If you want to isolate to exact component(s), then take readings of Charging IC with only AC adapter, no battery, laptop off.
          Your readings OFF_with_Battery doesn't show much difference between Good and Bad.
          Perhaps readings without battery will pinpoint something to debug.
          • classicandy
            • Apr 2018
            • 308
            • Nigeria
            Readings without Battery has been attached now
            • classicandy
              • Apr 2018
              • 308
              • Nigeria
              I did notice Resistor R334 had burnt out and I've replaced it and still no power on with AC only.....
              Initially, I noticed the DC Jack had a short between the AD_ID and +VIN because the plastic separating it in the Charging port had broken BUT i have replaced the charging port and still no success.....
              • IamPritesh
                • Aug 2017
                • 356
                • India
                DOES ad_id goes directly to IO chip ? COuld be possible that IO chip might have got faulty due to high voltage input.
                • mobotest
                  • Mar 2020
                  • 26
                  • US
                  I would expect pin10 in OFF_Without_Battery to be 0V as it does in mine after mine was functional.
                  But IamPritesh may be onto something more solid.
                  According to your schematic, AD_ID is an input for "Smart Adapter Type Check" and produces AD_TYPE which is input to the SuperIO chip.
                  • bekirsalman
                    • Nov 2016
                    • 137
                    • turkey
                    The capacitors of the io chip may be defective therefore the io chip may be defective
                    Electronicman
                    • classicandy
                      • Apr 2018
                      • 308
                      • Nigeria
                      AD_ID passes through 2 resistors, R344 @100 ohms and R337 @10k ohms to AD_TYPE @Pin 71 of IO (U14)
                      I might have to agree to the possibility of the IO being faulty. Only solution now would be to change it I guess. Or anyway around that???
                      Is the IO the programmed type?
                      • classicandy
                        • Apr 2018
                        • 308
                        • Nigeria
                        Its R344 I meant here not R334.... Sorry for the mix up. R334 is the same resistor though but for U93 motherboard instead.
                        • classicandy
                          • Apr 2018
                          • 308
                          • Nigeria
                          True, the IO may be defective..... Would try to look for a replacement for it.
                          • classicandy
                            • Apr 2018
                            • 308
                            • Nigeria
                            Thanks for all your efforts @mobotest, @IamPritesh and @bekirsalman ...... Would let you all know the outcome as soon as I get the IO replaced.
                            • mobotest
                              • Mar 2020
                              • 26
                              • US
                              Since R344 is part of "Smart Adapter Type Check" circuit, damage to it would make the IO suspect for the problem your laptop has.
                              In addition to replacing IO, check the diode, resistors, and capacitors that are part of the "Smart Adapter Type Check" circuit.
                              • classicandy
                                • Apr 2018
                                • 308
                                • Nigeria
                                Hello everyone here, so I've replaced the IO with a known working one and yet, no change. It still doesn't Power On with Adapter ONLY. What can I be missing now?
                                • mobotest
                                  • Mar 2020
                                  • 26
                                  • US
                                  Did you check the diode, resistors, and capacitors that are part of the "Smart Adapter Type Check" circuit?
                                  • classicandy
                                    • Apr 2018
                                    • 308
                                    • Nigeria
                                    yea, they seem to be okay
                                    • classicandy
                                      • Apr 2018
                                      • 308
                                      • Nigeria
                                      I now have 2 exact models suffering from the same issue/problem.
                                      • classicandy
                                        • Apr 2018
                                        • 308
                                        • Nigeria
                                        My assumption from this is that, when battery is inserted, the battery triggers something that the AC adapter is no longer triggering which enables it to power On.
                                          HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 03:44 PM
                                          HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
