da0nm3mb6e0 rev e USB device not detecting
  • kalilinux25
    • Mar 2018
    • 2084
    • ZAMBOANGA SIBUGAY
    I tried a bootable usb to format the laptop but it wont detect
    I've check the voltages but it has voltage of 5v preset on the port . Is it a bios problem?
  • kalilinux25
    • Mar 2018
    • 2084
    • ZAMBOANGA SIBUGAY
    Re: da0nm3mb6e0 rev e USB device not detecting
    I've check the U21 ic Pin 2-4 has 5v present
    • Francisco.s
      • 686
      • Spain
      Can you boot from hdd and check if usb is detected from os installed in this hdd?
      • Mazorca
        • Jan 2017
        • 463
        Is USB enabled in Bios settings?
        • groomit
          Dell XPS 9365 2-in-1 LA-D781P "No bootable device" and low VCC_CORE
          by groomit
          currently I'm tinkering with above mentioned broken device. It started with a shorted PD controller. I replaced it and have an open topic on this forum on reprogramming it.
          Currently I'm powering it with a bench supply soldered to the battery connector (laptop battery is dead).
          This way the device is booting into BIOS and Diagnose mode fine. But when I try to restore the factory image during diagnose the laptop always greets me with "no bootable device".
          Looking at the bios the ssd is recognized (shown with type and size in some storage menu). But...
          10-23-2024, 02:06 PM
        • minaedward
          Dell 5300 2 in 1 no bootable device
          by minaedward
          Hi
          I have a Dell Latitude 5300 2 in 1 laptop that boots into this message "no bootable devices found"
          It has an nvme ssd drive installed which is tested and working fine with windows 10 installed but it does't show in BIOS at all
          I tried updating the BIOS through usb and when it restarts there is no chnage I am stuck with the same BIOS version
          Please Help
          09-16-2024, 02:35 PM
        • Yolofolkss
          Asus X99-pro/usb 3.1 Usb overcurrent device reoccurring issue
          by Yolofolkss
          Hi this is a really odd case.
          I have removed all of the esd ic for USB 3.0 and 2.0
          I measured all of the data lines and 5v usb voltage lines there are no shorts
          all of the USB ports have no damage
          Clearing the bios using the jumper wont help.
          it is still showing USB overcurrent device
          the only temporary fix I've tried and worked so far is flashing the bios
          and the error is gone
          but when you start the motherboard with a USB device still attached
          the USB over current device error is back. the bios needs to be externally flashed...
          01-09-2023, 04:21 AM
        • mrdevil
          Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
          by mrdevil
          Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
          However, after about 12 months, I had a number of these stop working...
          01-08-2025, 03:19 AM
        • Stachujones
          Dell XPS 13 9370 unknown USB devices in device manager
          by Stachujones
          Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
          Device manager says "unknown device, failed to request device descriptor"
          Can somebody point me in right direction what to check?
          I updated bios to the newest version and thunderbolt controller firmware still no luck
          04-05-2025, 07:35 AM
