Fujitsu a514 no backlight
  • Anethra
    • Dec 2018
    • 70
    • Turkey
    hello there. laptop working fine and has screen but no have bachlight. i seen bios screen. ive tried different panel but same problem. anyone can help me to fix this issue?
    vled = 19v
    vcc = 3.3v
    Bl_en = 3.3v
    clk_edit = 3.3v
    data_edit = 3.3v
    bl_pwm = 3.3v
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Fujitsu a514 no backlight
    Very strange because all conditions to have a backlight are present. The measurements are taken from the 40-pin lvds connector? Or at the motherboard side?
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Anethra
      • Dec 2018
      • 70
      • Turkey
      taken panel side. i check to cable one by one. panel is 40pin slim led
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Hmm, strange...
        Take the measurements again but on the screen motherboard test points.
        • Anethra
          • Dec 2018
          • 70
          • Turkey
          I couldnt do the measurements because the customer wanted his laptop back. Thank you for your time anyway
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
            Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook U Specification for Upgrade or Repair
            This specification for the Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7411 boardview and LIFEBOOK U7411 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 03:40 AM
          • DanPoka
            by DanPoka
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
            Fujitsu LIFEBOOK LIFEBOOK U9311X Hybrid (2-in-1) U Specification for Upgrade or Repair
            This specification for the Fujitsu LIFEBOOK LIFEBOOK U9311X Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U9311X boardview and LIFEBOOK U9311X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 01:00 AM
