Request for info on a SPI ROM part
  • pc1staid
    • Apr 2014
    • 55
    • England
    Hello guys and gals on this forum.
    I may be posting in the wrong section, if so, would a Mod please put it in the relevent forum.
    After information on a SPI Flash ROM for availability and/ or an alternative.
    In situ at the moment is a Macronix MXIC MX25U8033E M21-12G SOP8 IC
    I know this is a 1.8v chip. The Laptop ( Acer Aspire A314-31) has suffered liquid ingress where there was no power. I have solved the power side of things, so I now get power on/ battery showing as charging etc, but no display. I have a Chipmunk ( normally use this on Apple machines) which seems to work on PC based laptops as well, that shows me the CPU is doing nothing. Upon removal of the adapter whilst powered on does give a beep indicating its removal... so there is life there somewhere.
    There was a little corrosion around the SPI ROM which I have cleaned but no further forward.
    I have removed the SPI ROM and placed it on my programmer (CH341A) with the 1.8v adapter and it reads as a 4MB/32Mbit unit. The data sheets show this as a 8Mb/ 32Mbit unit and this is further confirmed by the BIOS file ( found at this link:- https://www.badcaps.net/forum/showthread.php?t=67716 )
    I feel the SPI ROM is damaged and wish to get another..... even though I can find data sheets, I can not find a source. Aliexpress do not have any, well the ones they do have not got the code M21-12G, which I believe is the package type.
    Can anyone tell me if there is an alternative SPI ROM I can use ( Winbond etc), or even better if someone has the said IC on a dead donor board, able to supply it.
    Any help is greatfully received.
    Thanks for you time folks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Request for info on a SPI ROM part
    just throw in any bios ic with same voltage and capacity. they are "all" the same
    • piernov
      • Jan 2016
      • 4439
      • France
      They are not. Dual SPI/Quad SPI mode, different clock tolerance, different command sets… In a lot of cases it'll work, but better use the same one or at least pick on in the VSCC table to avoid issue with ME/TXE.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        thats why i wrote "all"
        • pc1staid
          • Apr 2014
          • 55
          • England
          Thanks for the replies @KTMMOTOCROSS and @Piernov.
          So, would this one do the job? .....
          https://uk.rs-online.com/web/p/flash-memory/8696195/
            • 21874
            The MX25U8033E isn`t supported by the CH341A software that you`re currently using,thats why the chip size reads differently. Try NeoProgrammer software instead,its supports the MX25U8033E. You just have to change the language to english,choose CH341A as the hardware and select the chip manually. If you want your bios fixing post it in the "Bios Requests ONLY!" section .
            NeoProgrammer - https://www.badcaps.net/forum/attach...7&d=1599328542
            • pc1staid
              • Apr 2014
              • 55
              • England
              I will give that a go. i am going to try the new software first. If that fails I will be back on the hunt for a SPI ROM
              Thanks for the advice SMDFlea.
              • edugimeno
                Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                by edugimeno
                Hi There!
                I'm trying to help my friend who owns a restaurant be just bought.
                He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                It's stuck using, I guess, the 2 sided tape that comes with the strip
                The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                09-05-2024, 09:34 AM
              • G-Sting
                iPad Pro A1876 SHORT Part Identify Help Needed
                by G-Sting
                So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                SO My main concern is what part should i order what should i search the name for ?
                on Ipad...
                05-15-2025, 09:30 AM
              • Yanleb
                Panasonic part number in service manuals
                by Yanleb
                In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                For an example, look at the attached PDF.
                Do you have a way to cross reference the Panasonic part number with the actual part number?
                Thanks....
                07-03-2023, 08:16 PM
              • FreakyMex
                Trouble to identify part (Lunii screen) for replacement
                by FreakyMex
                Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                02-17-2025, 01:16 AM
              • rookieme
                820-00426 alternative smd part
                by rookieme
                can somebody confirm if I can replace ISL95826AHRZ with ISL95826HRZ
                I can't find datasheet but I feel that it should be the same
                04-06-2023, 04:04 AM
