i need help to find mosfeat
  • nabilgo
    • May 2016
    • 300
    • L.A
    what's the équivalent of this MOSFET mdv1525
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    Re: i need help to find mosfeat
    mostly every mosfet with same or higher current, package and channel can be used
    • nabilgo
      • May 2016
      • 300
      • L.A
      ok thx my friend
      • nabilgo
        • May 2016
        • 300
        • L.A
        i used 7702a the laptop work but i cant find cpu core that whu im asking
        • Blastsail
          Help find compatible MOSFET from Asus FA506 DABXBMBAD0
          by Blastsail
          I have a coffee damaged asus laptop with shorted mosfet for vram. Trying to find replacement but I am struggling to. Markings are M3966M and I have attached image of mosfet. Schematics are available which say chip is a QM3966M6 but i am unable to find this chip no matter what combination of letters i put in. I can see there exists an m3966m3 chip but this appears to be the wrong size and markings are different.
          I have attached schematic as well to help, mosfet is on page 44 of pdf. I do not know where to start to find a compatible mosfet so any help will be greatly appreciated....
          05-07-2022, 07:35 AM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • Oliver111
          Asus UX535L.Help to find name of mosfet driver
          by Oliver111
          Hi! Please help to find mosfet driver name. Laptop is Asus UX535L. CPU PWM - NCP81215D, Mosfets on CPU - fdpc5030sg. Driver - DYU or DYP, cannot find it on google....
          04-08-2024, 07:47 AM
        • madan1
          How to find the faulty mosfet?
          by madan1
          Hi everyone.
          I friend asked me to try to fix his gigabyte ga-x99-ud4 motherboard which is not booting. After some probing, it turned out that the CPU power supply is shorted.. but not only vCore, but cpu +12V also ( the "atx +12v x4" connector ).
          Basically almost everything around and under the cpu socket is shorted to ground.
          +12V on the ATX 24pin connector seems to be fine. Indeed nothing on the 24pin connector seems to be shorted.
          For the vCore rail there are 6x IR3550 mosfets and it looks like everything on them is connected in parallel ( except...
          06-04-2021, 06:05 PM
        • MaineFix
          How to find the correct Mosfet on a laptop I need to replace
          by MaineFix
          I don't know if this is the correct forum or if I should be posting in another one. I have a broken mosfet that needs to be replaced on a yoga motherboard.
          The mosfet is labeled:
          SM
          3424n
          CX427
          I have found a replacement before searching a combination of these number but this one is giving me issues.
          Am I going about this wrong?
          Advice and any and all tips is greatly appreciated.
          01-16-2023, 12:34 AM
