MacBook Pro 15" Mid 2014 Fans Spin No post
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    MacBook Pro 15" Mid 2014 Fan Spins for 10 seconds then shuts off then turns on again.
    The computer needed a new battery and we installed the new battery to finally get to install a NEW OS on a new ssd. The computer was installing the OS then we walked away from it. We walked back to the computer and it was turned off. So we decided to see why it was off, we turned it and it didn't post. Remember this was a fresh new OS install of Mac OS Mojave. We looked to see if the fans turned on and they did. We are leaning towards maybe a failed bios chip but its odd that it was working perfectly until we installed a new OS. Maybe we are missing something here. We can solder and repair but currently we do not have the board schematic atm. If you have any suggestions and also the BOARD schematic and PDF please provide it as well! We will be grateful to those that suggest anything! Would hate to purchase a logic board when this one was working perfectly fine.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: MacBook Pro 15" Mid 2014 Fans Spin No post
    The macOS Installer can perform a BootROM update as part of the installation process. It's rare, but corruption can happen and in this case you have to flash EFI with an external programmer.
    Schematics and boardviews are most likely already posted for both the IG and DG models.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      So basically new BIOS chip as expected?
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Replaced the Bios chip with a new Bios Chip programmed for this model. Still has the 10 second fan spin SHUT OFF then spin again. No post no screen display. Any suggestions here? Is there something I should be looking for? The board turns on and like stated the computer was installing a new OS (Mojave) and it failed to install and turned itself off and it never turns on again. So the next step is find out what you guys think it may be. Any suggestions would be great or Logic board level repair suggestions as well and where to look at on the board view/PDF files. Thanks again!
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          BUMP any help would be greatly appreciated!
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            One more bump! Need a little help here.
            sigpic
            • Weelcup
              TopTech
              • Oct 2017
              • 307
              Can you upload the bios dump. The original one.
              Also the board number. I.e. 820-xxxx.
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                when pc is cold, it turn off always after the same time when pc is getting hotter ?
                what was the cause of this malfunction? water spill... fall damage... nothing ?
                board code ? could be that tantalum capacitors failing ? check voltage on that small tantalum capacitor ( board code would help to see if they suffer from that problem) and check voltage when it tutn off ...
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Board model number is 820-3662 for IG or 820-3787 for DG. No tantalum capacitor failure on these.
                  Symptoms and history were described in original post.
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    volts on L8710?
                    edit: try boot with battery only... then with psu only and see if still turn off.
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 674
                      Hey Dellxps15,
                      We have tried to boot without battery and with. like stated in the original post the computer booted and wouldn't post past the Apple Logo when trying to get a os loaded to install a new os on the SSD. The battery was the culprit originally. We installed a new battery (OEM) and it booted into the USB OS (Mojave) and we were able to start installing a new OS. We walked away and then the computer was shut off. We tried to boot it again and can hear the fans spin. The funny thing is they spin for exactly 10 SECONDS then shuts off then restarts and does it again. No post no nothing. WE went ahead and purchased a new BIOS chip and replaced it...sadly no fix with new bios chip. Computer also had no water damage or spills etc in its history. Just needed a new battery pretty much.
                      sigpic
                      • dellxps15
                        • Feb 2014
                        • 1598
                        • italy
                        ok, so now u dont have apple logo. can u read volts on L8710 ?
                        • Weelcup
                          TopTech
                          • Oct 2017
                          • 307
                          Suspecting bios me region damage.
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 674
                            Thats crazy wouldn't a new bios chip fix that issue @weelcup? we replaced it with a new bios chip for this year and model. Odd that it didn't solve it whatsoever.
                            sigpic
                            • Weelcup
                              TopTech
                              • Oct 2017
                              • 307
                              Well, how can you guarantee the "new bios chip" is reliable.
                              If you have a programmer and can program it just send me the the board number and i will send you a bios dump to flash it. It will be very fraustrated if the bios was the issue and we spend all the time to find a hardware issue.
                              So just to make sure it is not the bios, a good clear dump will judge.
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 674
                                Ok I will take a look tonight. I never had to flash our boards. Usually we just do schematic repairs.
                                sigpic
                                • Herby94
                                  MacBook Pro A1707 Won’t Boot – No Display, Fans Spin Briefly
                                  by Herby94
                                  I’m currently having an issue with my MacBook Pro (A1707). It doesn’t power on or make any sounds.
                                  • The charger is a generic third-party unit that had a loose connection at the AC input (127VAC). I fixed it, and now it delivers 20VDC to the laptop.
                                  • When connected, the fans spin for about 30 seconds before shutting off.
                                  • No display, no audio, and no signs of life during this time.
                                  Any ideas? Could this be a logic board issue, or is the charger still a problem? Thanks in advance!...
                                  08-07-2025, 08:59 AM
                                • Gigabit2
                                  MacBook Pro Mid 2012 turns on, fans spin for five seconds and turns off, repeats
                                  by Gigabit2
                                  I have a MacBook Pro Mid 2012 with 820-3330-B board.
                                  The laptop shows a green light on the charger, turns on and the fans spin for about five seconds. Then it turns off and this repeats over and over.
                                  Before it turns off, the SuperDrive (DVD/CD drive) makes a noise like it does when it first turns on from cold (on a working machine).
                                  I am stumped, can anyone help?
                                  06-22-2022, 09:29 AM
                                  Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                                  This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                  09-07-2024, 02:20 AM
                                  Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                  This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  09-06-2024, 09:30 PM
                                  Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                  This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
