A1502 restarts with battery connected (without battery no problems)
  • mbcontrol
    • Apr 2020
    • 13
    Hello everybody,
    I'm working on a A1502 (820-4924A) that keeps restarting when the battery is connected. I've already tried a new battery. The problem also exists when the charger and the battery are connected.
    Without a connected battery, the machine runs without problems.
    Sometimes he brings a message like "Your computer restarted because of a problem". Most of the time he restarts without any message during booting up (endless loop).
    Does anyone have experience with such a fault?
    Thank you for every tip.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: A1502 restarts with battery connected (without battery no problems)
    check datalines from battery and ofcourse whole charging circuit
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • code share
      Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
      by code share
      I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
      Here's what I've tried so far:
      • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
      • Booted successfully on AC power only with the battery disconnected
      • Visual inspection of the battery — no swelling, burn marks, or connector damage
      • Battery
      04-21-2025, 12:50 PM
    • survivalbloke
      Acer Predator Helios 300 - will not power up if battery is CONNECTED
      by survivalbloke
      This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
      06-25-2025, 12:20 PM
    • beogeek
      820-2915-A Wont power on with battery connected
      by beogeek
      Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
      I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
      After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
      So to cut the long story short I've replaced U7000,...
      02-26-2022, 01:29 AM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
