HP DA0R62MB6E1 Rev E Startup problem
  • NConstantinou
    • May 2017
    • 351
    • Cyprus
    Hi all
    i have the above motherboard which has the 19v rail, on PL11 i have 2.5v(battery coil), i have on BIOS and KBC 3.3v, power button 3.3v BUT i do not have the 3&5 V rails AND THERE IS NO SHORT.
    the PL22 (3v coil) gets the voltage from a capacitor pc223. pc223 one side has 4.89v and the side connected to the coil is 0v. capacitor is not short.
    same with PL24 (5v) is connected to pc234 witch on one side is 4.89v and the other side which is connected to pl24 is 0v.
    on IC PU9 and PU10 the S5_ON pins are 0v.
    Tracing S5_ON is comming from KBC3940.
    is it a problem with KBC!If YES
    is there any compatible IC!
    On power switch i have 3.3v and when i press it goes to 0V and then to 3.3v.
    on PQ32 one side is 19v and the other side is 2.5V charging mosfet
    Please advice
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP DA0R62MB6E1 Rev E Startup problem
    Check pin11 of PU9/10 for shorting. What is the voltage on PIN 1/6/7/11 of PU9??
    • NConstantinou
      • May 2017
      • 351
      • Cyprus
      Thanks for the reply
      on pin 11 of pu9 i get 3.3v
      on pin 11 of pu10 i get 5v
      pu9 pins
      1- 19v
      6- 3v
      7-0v
      11-5v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        It seems ok, Pin7 no voltage output is expected when EN is missing. Missing S5_ON is the issue. Try replacing KBC. I dont think there is any alternative to Ene3940.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          However, before going for kbc replacement, have you checked all the requirement of kbc??
          • NConstantinou
            • May 2017
            • 351
            • Cyprus
            Not really because i thought if i do not have S5_ON then there is problem with kbc.
            keep in mind that PQ32 Mosfet on one side i have 19v and on the coil side 2.5v.
            does this matter!
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              For any IC to work, you need to check its basic requirement first. If all the requirements are not met, definitely no output. Same applies to kbc as well. Pq32 is not bothering me at this stage. first we need to fix 3/5 alw line.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                first u need to fix 3VL line for KBC standby. without it u dont have EN signal for 3/5V.
                • barkinaksoy
                  • POLAND
                  Hello i have the same problem as here did you fix it ?
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    PQ32 one side is 19v and the other side is 2.5V normal. Is there a light in the capslook led lamp, blink. its need bios programming
                    I'm not happy to be so strong. because it's not humanly
                    • flibidy
                      Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                      by flibidy
                      I have here a Magnum IA.100 which belongs to my parents.
                      The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                      Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                      What Ive done........
                      01-01-2025, 01:26 PM
                    • bouny56
                      Lenovo E15 Nm-c421 usb-c work only in one side
                      by bouny56
                      ​Hello
                      Laptop E15 I5 10gen
                      Mb nm-c421
                      I have a problem with the usb-c power dc.
                      The motherboard start only in one side of the usb-c
                      Replace the usb-c port 2 times same problem
                      With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
                      Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
                      Can the pd controler be the fault ? Or something else maybe ?
                      Thx
                      02-11-2025, 03:15 AM
                    • estabilito
                      Acer Nitro AN515-55 weird behaviour on startup
                      by estabilito
                      Hi, I've just repaired acer nitro an515-55 with specs:
                      i7-10750h, rtx2060.
                      Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
                      After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
                      i've tried different bios, different vbios and same behaviour - clean windows install too.
                      Do you have any idea?
                      08-13-2025, 02:52 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
