MacBook Air 820-00165-A PPBUS-G3H <1V
  • Gpl
    • Jun 2018
    • 9
    • Italy
    Hi all, i would like to learn to repair pcb, i'm tring to repair a macbook air 1466 with mb 820-00165-A
    I got ppbus_g3h about 0,9-0,8V, fuse is ok,
    PP3V42_G3H present
    the only thing i can notice is a burn on the cable of the display
    What can i check ?
    thanks.
  • luckydip
    • Aug 2016
    • 159
    • uk
    Re: MacBook Air 820-00165-A PPBUS-G3H &lt;1V
    check voltages without anything else attached - only dc-in board. Measure resistance on ppbus_g3h.
    • Gpl
      • Jun 2018
      • 9
      • Italy
      Thanks, 0,9V is without anything attached, i will check resistence
      • Gpl
        • Jun 2018
        • 9
        • Italy
        Resistance to ground on ppbus_g3h is 600ohm
        • Gpl
          • Jun 2018
          • 9
          • Italy
          Removed fuse F7140 still have low voltage on ppbus_g3h
          checked PPDCIN_G3H, 1,7V goes down to 0,8V
          PPDCIN_G3H_ISOL : 15V
          hope to find the sort :-)
          • piernov
            • Jan 2016
            • 4435
            • France
            Not possible. PPDCIN_G3H_ISOL is derived from PPDCIN_G3H.
            • Gpl
              • Jun 2018
              • 9
              • Italy
              Sorry, my mistake,
              PPDCIN_G3H = 15,04V and also PPDCIN_G3H_ISOL
              PPDCIN_G3H_INRUSH = 0,9V
              CHGR_SGATE_DIV = 0,9V
              PP5V1_CHGR_VDD = 5,14V
              PP5V1_CHGR_VDDP = 5,14V
              • piernov
                • Jan 2016
                • 4435
                • France
                What about ACIN and DCIN of U7100? Resistance between pins 17/18 and between pins 27/28 of U7100?
                EDIT: and resistance between pins 26/27 of U7100 as well
                • Gpl
                  • Jun 2018
                  • 9
                  • Italy
                  CHGR_ACIN = 3,92 V
                  CHGR_DCIN = 14,72V
                  resistance between pins 17 and 18 is 3,4 ohm
                  resistance between pins 26 and 27 is 164,9 kohm
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    And between 27/28? If it's 20 ohms you can try replacing U7100.
                    • Gpl
                      • Jun 2018
                      • 9
                      • Italy
                      Yes, between 27/28 of U7100 resistance is 20,1 ohms
                      can i use a new U7100 ?
                      I also have another board with fan that spins but not boot
                      • envym
                        by envym
                        Hi everyone!
                        06-27-2025, 08:54 AM
                      • Yosua
                        MACBOOK AIR 1466 DEAD
                        by Yosua
                        HELLO FELLOW COLLECTORS, How are you doing, I hope GOD always gives us good health, I'm here asking for help to work on this MacBook Air, to be honest, this is the first time I'm dealing with a MacBook machine, and I immediately decided that the ISL 6259 IC and after I replaced it it still didn't work and I found that the CHGR_CSO_N & CHGR_CSO_P pins had a short circuit.
                        can anyone help me guys?​
                        02-17-2025, 02:07 AM
                      • tobeend
                        Bypass mdm macbook m2 ventura
                        by tobeend
                        1. RESET MACOS WITH IPSW
                        a. Power off MacBook, press and hold the power button to enter Recovery
                        b. Open Disk Utility, remove Macintosh HD
                        c. Reboot, connect to the network to Activate Mac.
                        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                        e. Release the other keys, but keep holding the Power key for another 10 seconds
                        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                        05-26-2023, 07:18 AM
                      • Lgolebio
                        MacBook AIR 1466 [ 820-00165-A] = Missing "PM_SLP_S5_L"
                        by Lgolebio
                        Hi
                        MacBook AIR 1466
                        MB: 820-00165-A
                        I followed the power scheme https://logi.wiki/images/a/af/G3_-_S...ell.drawio.png. I have all voltages up to "PM_SLP_S5_L" = 0V. When I plug the charger it tries to power on, goes to 0,250A then goes to 0,023A and does nothing. No fan spin.
                        I'm confused, board looks good under microscope. No corrosion.
                        05-15-2023, 04:52 AM
                      • SarcasticOP
                        General question about MacBook power rails for repair.
                        by SarcasticOP
                        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                        • PPBUS_G3H (12.6V-12.8V)
                          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                        • PP3V42_G3H (3.42V)
                          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                        • PPVRTC_G3H (3.3V)
                          • This
                        12-12-2024, 05:50 PM
