HP 15z-ab motherboard no power
  • Zibbo
    • Mar 2017
    • 204
    • Zimbabwe
    I am attempting to repair a HP 15z-ab motherboard board number DA0X22MB6D0 REV D. When the charger is plugged in, the white led on the charger port turns on and when the power button is pressed 3V/5V comes up but the suspend voltages don't come and the fan doesn't even spin.
    I have checked for shorts on all the mosfets, I have checked for shorts on all the inductors, I have flashed the bios and I have replaced the 32.768KHz oscillator.
    Checking around the EC I have noticed that ECRST# and ECPWROK are both low, however RSMRST# is high. Any pointers on what I should check?
    Schematics and boardview attached
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: HP 15z-ab motherboard no power
    what voltage are missing when press the PWBT DNBSWON# SUSB# SUSC# S5_ON +5VS5 +3VS5 ?
    • Zibbo
      • Mar 2017
      • 204
      • Zimbabwe
      After DNBSWON#, S5_ON is present but SUSB# and SUSC# are missing
      • Techtiger
        • Oct 2014
        • 1602
        • france
        5vs5 +3vs5 ?
        • Zibbo
          • Mar 2017
          • 204
          • Zimbabwe
          +5VS5 and +3VS5 are present
          • Techtiger
            • Oct 2014
            • 1602
            • france
            PU13 pin13 & 8 voltage ?
            • Zibbo
              • Mar 2017
              • 204
              • Zimbabwe
              There is 0v on both pins
              • Techtiger
                • Oct 2014
                • 1602
                • france
                find out R5036 10K for any short, EC_RCIN# is low test resistance to ground U5001 pin 2 & 37 , pin 76 30 31 voltage ?
                • Zibbo
                  • Mar 2017
                  • 204
                  • Zimbabwe
                  No short on R5036, resistance to ground on U5002 pin 2 is 1370 Ohms and infinite on pin 37.
                  Pin 30 = 0v
                  Pin 31 = 3.3v
                  Pin 76 = 2,95v
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Pin 30 = 0v
                    Pin 31 = 3.3v
                    Pin 76 = 2,95v
                    if you have power LAB apply 3V to pin 37 SIO & see if any results on out put
                    • Zibbo
                      • Mar 2017
                      • 204
                      • Zimbabwe
                      I injected 3v on pin 37 and strangely ECRST# is now going high even after unplugging the charger. I tried injecting 3v on ECPWROK but the board still doesn't turn On
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        test
                        G1 SHORT_ PAD1 for 1.5V
                        R164 10K +3VS5
                        voltage on PL12 PL13 ?
                        +1.8VS5 is present ?
                        put a jumper from PU12( pin1 to 13) PU13 (pin1 to 13)( pin7 to 8) PU14 (pin1 to 13)( pin7 to 8) CPU should get worm power up & see
