Asus N53sv not powering on
  • JustX
    • Feb 2019
    • 70
    • iran
    when i remove bios ic i have all voltages on board (3.3,5 and voltages on bios pins except pin numer one) and when i put it backk all of em are gone
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: Asus N53sv not powering on
    The cmos battery is in place with a good voltage ?
    • JustX
      • Feb 2019
      • 70
      • iran
      yes it is, im really stck with this one.
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        Try replacing the BIOS chip with a known good one.
        • JustX
          • Feb 2019
          • 70
          • iran
          i did that still the same i chked i put down the bios chip and lift pin one and i have all voltages and other pins of bios chip, but when i connect pin one laptop goes dead
          • Spider1211
            • Oct 2019
            • 532
            • Mauritius
            What is the resistance to ground on pin 1?
            • JustX
              • Feb 2019
              • 70
              • iran
              with red prob on pin 1 i get 0.8 mohm
              with black prob on pin 1 i get 0.4mohm
              • Spider1211
                • Oct 2019
                • 532
                • Mauritius
                mohm = milli ohm
                Mohm = mega ohm
                If your reading is milli ohm, you have a short on that line.
                • JustX
                  • Feb 2019
                  • 70
                  • iran
                  mega i meant Mohm
                    • 21932
                    The problem could be with the PCH or EC.Checck by removing R2837,then check voltage on bios pin 1. SL2802 pin 1 goes to pin 101 on the EC through R3050
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      Wasn't notified of new comments. Anyways, agreed with SMDFlea. Remove the resistors mentioned and put them back one at a time to narrow down if issue is with PCH or EC.
                      • JustX
                        • Feb 2019
                        • 70
                        • iran
                        thank you for responding
                        i did that already and nothing happend in the end i changed pch and ec on the board and still the same at somepoint i changed charge ic bq24740 and then i had low voltage o pin 8 with bios chip on board and my pwm was getting hot i changed that too and chkd mosfets and didnt find solution. i was hoping fixing this one cuz i was couros why this is happening
                        but the costumer is in a rush so i have to let it go
