PB easynote mh36 wifi adaptor disconnects & touchpad faulty
  • Motherfinboard
    • May 2020
    • 68
    • United Kingdom
    Re: PB easynote mh36 wifi adaptor disconnects & touchpad faulty
    I have been using Snappy to get the free drivers,any other recommendations for a reliable source?
      • 31025
      drivers are best from the maker of the chips
      • Motherfinboard
        • May 2020
        • 68
        • United Kingdom
        I swapped out the WiFi card for another of the same brand from a identical laptop and so far WiFi is staying connected.
        As for the physical mouse buttons, one must have lifted slightly as no contact on pressing with multimeter attached. Resoldered and now both buttons are working.
        Can anyone recommend the best windows for this laptop to run on, as vista just keeps giving warnings on website pages and do not load properly using Chrome. Internet explorer is even worse.
        Thanks for the help and advice for sorting the problems so far all. ��
          • 31025
          7 and/or Linux
          if you want to have both, you MUST install 7 first and leave unused space on the drive
          • Motherfinboard
            • May 2020
            • 68
            • United Kingdom
            Thankyou
              HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
              This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
              09-06-2024, 08:50 AM
            • Spudgun
              Why doesn't current just bypass faulty capacitors.
              by Spudgun
              Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
              04-01-2025, 10:33 AM
            • Simonc123
              CH341A bios chip wont fit 1.8v adaptor holder
              by Simonc123
              Hi guys, I need a bit of help. I use a CH341A programmer, which is fine for 3.3v old-style bios chips. I need to reprogram some 1.8v chips, which are QFN type chips. I have the 1.8v adaptor for that slots onto the programmer, which does step the voltage down to 1.8v, but as you can see in the picture added, it doesn't fit in the IC holder.
              Please see the 4th picture that shows what looks like what should work for the QFN IC (highlighted in red). The issue is that the 8 pads on the programmer are too long and short out the IC. Is it a case of putting kapton tape over the center ground...
              03-09-2025, 08:54 AM
            • b-slayer
              Acer A317-53 need help to disable faulty onboard ram
              by b-slayer
              Hello.
              I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
              - first one is to modify le bios to disable the onboard ram.
              - second one is to disable the onboard ram by desoldering some components on the mainboard.
              so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
              so i found that my motherboard...
              10-12-2024, 03:46 AM
            • brispuss
              Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
              by brispuss
              Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
              Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
              I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
              12-28-2022, 02:58 AM
