HP zbook 15 g2 - sound ( noise) problem
  • Jane
    • Aug 2010
    • 189
    When I use earphones , the sound from the earphones has a noise problem. When I stop sound( e..g put video in mute mode) the noise remains a little longer and then stops. The problem is ONLY when using earphones.
    Under Linux it is the same as with Windows 10.
    What can it be ? Thanks for help
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: HP zbook 15 g2 - sound ( noise) problem
    connect a desktop speaker to the earphone connector of the laptop. Then check the output sound.
    Possibly, the audio processing circuit of the laptop got defective.
    • Jane
      • Aug 2010
      • 189
      Thanks for your reply. Do you mean a capacitor on the path from audio chip to earphone connector can be a culprit?
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        yes, that is possible. But I have not enough experience on audio controller ICs.
        • courtcircuit
          Philips HTS8000 home cinema noise problem
          by courtcircuit
          Hello
          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
          Removed each of tyhe boards
          02-08-2025, 08:22 AM
        • hugocarmo
          Panasonic TX-24A1UN CRT Sound and Input problem.
          by hugocarmo
          Hi.
          I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
          It is imaculate inside, almost no dust or debris inside.
          The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
          So I started to look for a service manual, I found one, and started from the beginning.
          Most of the times the caps are the problem so I orderer all the caps for all boards,...
          04-26-2025, 07:45 PM
          HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation Specification for Upgrade or Repair
          This specification for the HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Firefly 14 G8 Mobile Workstation Bundle boardview and ZBook Firefly 14 G8 Mobile Workstation Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
          09-07-2024, 05:20 AM
          HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
          This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
