Hello Guys i have this MAcbook 820-00165-A i have a short to groung in PP3V3_S4 rail, i injected power to it and the U2800 Thunderbolt Host IC heat up ...its a BGA chip ... we dont use thunderbolt here so would the motherboard power on without this ic ??
MAcbook Thunderbolt IC Shorted !!
by vienzenMacBook Air A1466 EMC2925 (820-00165-A) Shorted PP3V3_S0
1. Problem of macbook is No Display
2. Found shorted caps on c1212
3. After removing the shorted caps (c1212) the reading in the c1212 pin1 is .003 in diode mode test, still shorted.
4. Help me..... -
by Dylan JonesHi all,
I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited... -
by dbuergiHi all,
i got a A1708 with water damage. I cleaned everything and the board started normal. But the next day i got 20v but no booting. Thermal cam showed over 160c (never had a chip getting this burning hot before) in U2800 and some shorts on the caps around it. After removal shortages were gone and i installed a donor U2800 which worked before.
Sadly now the device stays at 5v, 0,4a and 1,9w and i don't find the problem.USB ports worked fine before....03-17-2025, 06:27 AM -
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by reessiHello:
I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
I started on the ACER:
Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap... - Loading...
