MacBook only work with dc bench power supply charger
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys
    Im diagnosing a macbook A1181
    Work very well when plugged in with a dc bench power supply charger, doesn't work with a normal apple charger 🔌
    I've never come across such issue
    I know I didn't post any measurements, but it works very well with the dc bench power supply charger
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: MacBook only work with dc bench power supply charger
    Usually bad DC-in MOSFETs, sometimes gate resistors of DC-in MOSFETs or resistor between PPDCIN and ground.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
    • exerion5000
      DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
      by exerion5000
      Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
      below normal, as if it were operating in an extreme energy...
      10-15-2023, 02:12 PM
    • double_DD
      HP Thunderbolt dock G2 - "fixing" it so it can work without original HP charger?
      by double_DD
      Hi guys,
      I do hope this is not off-topic.
      I have this mentioned HP dock which is half-defective, as it sometimes work and sometimes not. But that's not my main issue at the moment.
      I don't have any more original HP charger, and I would like to "fix" the dock so I can use it without it. Has anyone tried it, or maybe does someone know how to effectively bypass the "comm" pin of the charger?
      Maybe someone has a schematic that would be useful? There are markings on the board that say P&Q 2019 CM-4 94V-0 E162264, but when I try searching...
      09-10-2024, 05:16 AM
    • echothegamer
      Macbook A1466 dies when charger disconnected
      by echothegamer
      Hello all,
      Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
      Details:
      Macbook 13' A1466
      Board (820-3209-A)
      Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
      Pictures below of Boardview and schematic...
      I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
      It's an older model and it is very likely that battery has become...
      10-28-2023, 12:00 PM
