Asus N56JN Boot issue
  • Spiderbite69
    • May 2020
    • 7
    • Italy
    Hello
    Starting by the 1st of May I'm having some trouble booting my Asus N56JN notebook.
    I think it's an HW issue, because i've already tried some solutions with always the same problem:
    • Booting from USB without HDD
    • Boot without RAM (and with only one bank and exchange each other)
    • Boot without wireless HW
    • Boot with and without battery (and with/without charger)
    • Disconnect CMOS battery for 30min
    • And also boot without various HW because the notebook was disassembled
    You can see the issue on this video on YT: https://youtu.be/QnswbaL2Syw (no backlight on the screen)
    As you can see, the HDD and WIFI LEDs are blinking in a strange way, and rarely after some time the PC starts, but most of the times it doesn't, and I have to manually turn it off.
    When it boots up everything is working perfectly, in fact I'm writing this post using the Notebook, no freezes, all the HW seems to work fine (GPU, RAM, WIFI, Ethernet, USB...) no issues at all.
    Now, when I don't need it I put it in sleep mode (don't know if it's the correct name in english, but it's when everything is saved in RAM) and there is no problem waking up the device.
    I have no idea about the solution...but i was thinking about a BIOS problem.. is it possible?
    Thanks for any answer
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Asus N56JN Boot issue
    Yes it's possible.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      May be some corrosion somewhere or cold solder joints.
      • Spiderbite69
        • May 2020
        • 7
        • Italy
        Originally posted by piernov
        Yes it's possible.
        Thanks, there's something I can do to be sure about it?
        • Spiderbite69
          • May 2020
          • 7
          • Italy
          Thanks, if that's what happened I think that the problem will show up even when the PC is on, but no problem at all after boot..
          Am I missing something?
          • Spiderbite69
            • May 2020
            • 7
            • Italy
            Yes it's possible.
            Any news please?
            • piernov
              • Jan 2016
              • 4435
              • France
              Well, dump & flash the BIOS and see if the behavior changes.
              • Spiderbite69
                • May 2020
                • 7
                • Italy
                Thanks,
                Sorry if I bother you but this is the first time i have to deal with this kind of problem.
                You suggest to change the eeprom with a new one or erase and flash this one?
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  It's better to use another SPI ROM of the same model if you have one lying around. Otherwise you can reuse the same chip after making sure you got a correct dump from it.
                  • Spiderbite69
                    • May 2020
                    • 7
                    • Italy
                    Ok, I'll do it, but first i have to buy the equipment to read the memory
                    I'll also buy the memory with the programmer.
                    I haven't found in the forum a general guide on how to do a dump and verify it, do you have a link to it?
                    Otherwise I'll find it somewere else on the internet
                    Thanks again for your support!
                    • lukkihapsi
                      Asus Vivobook X515JA Weird Boot Issue
                      by lukkihapsi
                      Asus Vivobook X515JA Laptop
                      Issue :
                      Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                      Tried :
                      Cleaned inside for dust, applied fresh thermal paste. No Change!
                      Removed keyboard, Trackpad, fingerprint sensor. No Change!
                      Removed Internal SSD. No Change!
                      Updated BIOS to latest version. No Change!
                      Removed battery and pressing power button for 1 minute. No Change!
                      Weird Part :
                      Upon turning laptop ON, screen lights up - stays black,
                      I...
                      07-07-2025, 12:07 PM
                    • Safio
                      Asus Rog Strix g15 g512LI BOOT ISSUE
                      by Safio
                      Hello
                      My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
                      i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
                      thank you
                      06-08-2024, 08:43 PM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • DynaxSC
                      ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                      by DynaxSC
                      I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                      Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                      Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                      The behaviour is also really very strange, i.e.:
                      • The disk shows always up in BIOS - so it is recognized, so far so good
                      • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                      02-23-2025, 01:33 PM
                    • jrodefeld
                      Asus laptop won't boot (no power) - possible bad caps?
                      by jrodefeld
                      I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                      The model:
                      Asus Zenbook Pro Duo UX582L
                      I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                      However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                      09-02-2024, 04:55 PM
