Asus N752VX not charging
  • BugDroid
    • Jul 2019
    • 5
    • Austria
    hey
    I have an Asus Vivobook which runs fine on AC but doesnt charge the battery.
    I did try with a new battery too, but issue remains.
    the charging power is activated by 2 mosfets and I am pretty sure the mosfets get their signal from a IT8995.
    can the chip be verified?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Asus N752VX not charging
    Does it run from the "new" battery, AC adapter disconnected?
    • BugDroid
      • Jul 2019
      • 5
      • Austria
      yes it can. as well as with the old battery. Until its running out of power of course.
      Just realized that I put the wrong name of the chip, sorry. The correct name is BQ24780S
      • piernov
        • Jan 2016
        • 4437
        • France
        Does it report the battery percentage properly? What's the voltage on the battery rail with:
        1/ AC adapter connected, battery disconnected
        2/ AC adapter disconnected, battery connected
        3/ AC adapter connected, battery connected
        • BugDroid
          • Jul 2019
          • 5
          • Austria
          values on the battery connector:
          1) 0V
          2) 13,8V
          3) 13,8V
          with no battery connected, windows says no battery detected.
          if the battery is connected and somewhat charged, windows reports the correct level. if the charger is connected, windows says charging, but the batt. level never changes
          I have 2 identical laptops here. The battery is 100% ok
          • piernov
            • Jan 2016
            • 4437
            • France
            EDIT: double check that both DC-in MOSFETs are not shorted drain/source/gate first.
            Ok, maybe a random failure of BQ24780S.
            You can either replace it right away and see if it solves the problem, or measure voltage on all its pins to try to find a hint.
            • BugDroid
              • Jul 2019
              • 5
              • Austria
              ok, this is the whole story:
              a few backs I had a problem with the LCD which startet to show black lines. After trying to bent the cable to the LCD and the small LCD on the LCD, the laptop wouldn't start anymore and the power supply would disable the DC output when connecting to the laptop. I found out that the 2 DC-in MosFets were shorted. I replaced them (and also the LCD) and the laptop would start again but wouldn't charge the battery anymore.
              I realized that the chip has a I2C interface. Is this of any use?
              • flat-earther
                ASUS X54H laptop thinks it's always charging even with charger unplugged
                by flat-earther
                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                Windows also shows ''Plugged in'' when charger is not connected.
                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                If I let battery run out and say it has 3% Windows will...
                06-24-2025, 09:32 AM
              • johnbeton
                Asus X415EA not charging battery
                by johnbeton
                I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
                So far I measured all the pins on the bq24780s controller with the following result:
                1. ACN = 0.0V
                2. ACP = 19.02V
                3. CMSRC = 18.5V
                4. ACDRV = 23.9V
                5. ACOK = 5.9V
                6. ACDET = 2.57V
                7. IADP = 0.17V
                8. IDCHG = 0V
                9. PMON = ?
                10. PROCHOT = 5.05V
                11. SDA = 3.3V
                12. SCL = 3.3V
                13. CMPIN = 0.47V
                14. CMPOUT = 6.0V
                15. BATPRES = 0.0V
                16....
                05-19-2025, 04:05 AM
              • thomasmagic
                not charging asus g531gw 1.6
                by thomasmagic
                hello,
                if you can help me, i have mainboard asus g531gw Rev 1.6 with short and no power
                i have found short on C3907 (PVDD_AMP) and remove it
                Actually machine works but battery is not charging. I have test with new one and i have too replace BQ24780S (charging IC) and same problem.
                It's not 1st time when i remove short after the battery is not detect
                On mybook i know we can make jumper beetween two lines for recognised this one
                do you have solution for pc and actually this mainboard? Thanks for your help ...
                06-19-2025, 12:54 PM
                ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                09-07-2024, 02:50 AM
                ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
