MacBook password EUFI protected
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys, im just wondering if i can use a windbond 25Q64a bios chip instead of Micron 25Q64a chip?
    I've been using a mini programmer for a long period of time, sometimes it can't write files on some other chips, on that case I usually use a windbond chip, and it works on most laptops...
    Can i do the same thing on this MacBook board?, is it gonna work?
    • 20279
    Re: MacBook password EUFI protected
    What model is your "mini programmer"
    • mnciks11
      • Aug 2019
      • 345
      • south Africa
      Thank you so much brother, it worked anyway, I downloaded the latest version of the software and it worked, i flashed the bios with new dump files and the password was removed
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • mferna14
        Password removal on MacBook Pro A2159
        by mferna14
        Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
        05-13-2025, 04:16 PM
      • ritalo
        MacBook Air 13 2014 - Remove EFI password
        by ritalo
        I have a MacBook Air 13 inches 2014.
        I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
        I know how to remove the password with a usb programmer.
        I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
        Then I have to find this value in the file : $SVS because it indicate where is the password.
        But I can't find the value.
        I have attached the file​
        Thank...
        05-14-2024, 12:10 PM
      • Danielreinaa
        HELP need password bios Macbook A1706
        by Danielreinaa
        Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
        Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
        Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
        gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
        Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
        09-07-2024, 03:47 PM
      • Nopslide
        HP Omen 15-dh0052nf power-on & bios password
        by Nopslide
        Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
        My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
        Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
        04-01-2024, 04:27 PM
