Pin 8 on the bios is shorted to ground
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Fellow brothers
    Kindly assist with the Following:
    MSI Gaming Laptop
    Model number: MS-1799
    Motherboard no:MS - 16J91
    VER: 1.0
    The bios chip is shorted, i removed the bios chip from the board but short is still there, pin 8 of the bios chip which I believe it 3.3v it shorted to ground, pin 1 and pin 2 are shorted to ground as well, pin 5 and 6 as well
    I injected 3.3v on pin 8, nothing is getting hot on the board, i even limited the current to 4 Amps but still nothing is getting hot
    Again there is coil which is shorted straight to ground, I believe it 3.3v output, still when i inject 1v there nothing is getting hot yet the board is taking 4 Amps
    Im totally confused
    Can someone help me please .
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Pin 8 on the bios is shorted to ground
    Check if PCH die warms up when injecting on 3.3V rail.
    OpenBoardView β€” https://github.com/OpenBoardView/OpenBoardView
    • whaldsz
      • Apr 2013
      • 395
      • Philippines
      You should observe a warming up of component at least, unless the short is below 1 ohms. Also replace the wire you use for injecting 3.3v. You need a larger diameter wire or else, nothing will heat up.
      • mnciks11
        • Aug 2019
        • 345
        • south Africa
        highly agreed, im gonna use a larger wire, it 000, straight to ground and my wire is getting hot instead, im gonna change my wire tomorrow and update you guys
        • mnciks11
          • Aug 2019
          • 345
          • south Africa
          thank you so much my brother, i did that, i even removed the heat sink and poured alcohol, no movement and nothing heating up
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            Check again if your wire is heating up. Shorten your wire if possible. Inspect using microscope if you have, could be a shorted large cap or the PCH is busted. You might need to leave it for 5-15 min and get back to it to check which area is warming up.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Agreed with others opinion-very likely its shorted PCH.
              • macabook
                πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
                by Vesko356
                08-11-2023, 03:27 AM
              • barry101
                Apple 820-3662 VCore shorted to ground.
                by barry101
                Hi, Would appreciate some help.
                I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                Get charger light but no fan spin or chime. No liquid damage.
                Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                06-24-2025, 07:34 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
