externally A1398 battery charging possible?
  • Richi_el
    • Nov 2013
    • 95
    • Koln
    Hello i have a problem with a MacBook battery.
    I want to charge it externally (without the pcb) because there is an issue on pcb and i cant charge it now.
    Have anybody a solution for charging the battery without logic board (outside of the book)
    I uploaded the pic with pinout and my measurings.
    Thnx
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Julian Bailey
    HP ProBook 445 G8 Battery not charging
    by Julian Bailey
    Hi all
    We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
    The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
    I have gone around the board with a MM and cant find anything
    Windows shows the battery fine,...
    10-11-2024, 10:34 AM
  • fisha
    Apple macbook Pro Retina A1398 Battery not charging
    by fisha
    Hallo everyone, my A1398 do not charging the battery and the battery also do not bin recognized. I did all the reset work, SMC reset and all the other reset options but nothing helped. on the SMC at pin 2 (DCIN) there are 20,4V coming in. at pin 16 (BGATE) which goes to the Q7155 Gate there are only 11,43V. at the pin 1,2 and 3 on the Q7155 (Source) there are 12,23V. Cap C7126 is not shorted. As I understand, the gate voltege have to by higher then the source voltege for the gate to clous so the battery can be charging, am I right? can someone help me with this? I guess that manny models are working...
    07-20-2024, 08:39 AM
  • piernov
    Laptop battery charging circuit
    by piernov
    1. Some theory
    1.1. Introduction
    Almost every laptop has a charging circuit of some sort, that does a few things:
    • Manages switching between AC adapter and battery power
    • Manages battery charging and generates power rail to charge battery
    There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
    • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
    • Narrow VDC (NVDC)
    Texas instrument has a nice overview of these technologies with some more details at https:...
    11-15-2020, 01:31 PM
  • kodox
    ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
    by kodox
    since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
    the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
    what i've done:
    - flashing...
    12-29-2024, 02:49 AM
