bios chip flashing...which file?
  • vince59
    • Nov 2017
    • 46
    • italy
    it is a general question about bios chip flashing. Let us assume that I want to flash a chip to replace a broken/unreadable chip.
    Not having a dump to flash, what file should I flash into the chip?
    As an example, I realized with my HP elitebook with BIOS W25Q128 that the bin file downloaded from the vendor/producer site is 8 MB while the dump or file to flash is 16MB.
    So my question is...how do I understand which file to flash into a bios chip?
    Thank you for you help.
  • vince59
    • Nov 2017
    • 46
    • italy
    Re: bios chip flashing...which file?
    ...no hints?
    • khaahk
      • Dec 2013
      • 812
      • Estonia
      HP does not generally provide you with a bin file. They provide installation program. One model might have multiple variations of mainboards - some may be with different size bios. Without further details hard to answer.
      Although HP latest bios updates let you generate a bin file - but after flashing these with programmer you have to update dmi information to provide serial nr. and other information.
      • vince59
        • Nov 2017
        • 46
        • italy
        Thanks for your useful answer. I am just trying to understand how it works.
        So assuming I have lost my chip and do not have the dump...what is the procedure to build the bios file to flash?
        You can keep the example to the HP for better undertstanding. I know they provide the exe file to install, but if we take it out the burned chip and mount a new one will the exe file work?...I do not think so.
        • khaahk
          • Dec 2013
          • 812
          • Estonia
          The most common way is to find bios dump from forums, if it is Intel based - then clean the management engine region and retransfer serial and windows license info if needed and then flash. Most producers do not provide full dump with bios update exe files, there is only bios region, ME and other information is missing - during the bios flash from exe these regions are not changed.
          • vince59
            • Nov 2017
            • 46
            • italy
            Thank you very much for your clear explanation that made me understand the whole process. I see the full bios dump inlcudes specific information that, off course, are not included in the bios release update.
            I guess if specific information, model related, are missing or mismatching the pc will not work
            • testaccgta
              Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
              by testaccgta
              Hi, everyone!
              I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
              I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
              09-01-2024, 08:24 PM
            • pirati
              by pirati
              Yesterday, 04:20 PM
            • JoWed
              Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
              by JoWed
              Hello Community,
              I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
              07-01-2025, 09:32 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
