Macbook 820-3787 Backlight Not Working
  • BoardNoob
    • May 2020
    • 6
    • U.K.
    Hello All,
    I'm quite new to this kind of this, Im just a lowly Process Engineer, so I am hoping you all can help me.
    I have been googling and researching for a day, and have discovered the relevant information I need to troubleshoot my 820-3787 motherboard backlight.
    So, here is some information which I hope you all can use to point me int he direction of a solution.
    When I check the back light capacitors, I get the following resistence:
    C7719/ 7716/ 7717/ 7715/ 7718 - 167 kilohms without screen connected. 83 kilohms with screen connected.
    Resistance to ground of Pin 1 on the LCD connector is 167 kilohms, but drops to 200 when the screen is connected.
    Resistance to ground of Pin 32 on the LCD connector is very low at 0.05 ohms.
    Resistance across L8300 is 2 kilohms. This also shows some continuity when black probe to earth and red probe on one end.
    Resistance across C8301 is 39 kilohms.
    Chip U2800 has a water indicator on it that is half red. And there is evidence of corrosion around the bottom of the LCD connector and L8300.
    It did have a meeting with water immediately prior to failing.
    My question is, which of the above should I replace (and where do I buy these parts?)
    Edit: Removed commas on numbers.
  • BoardNoob
    • May 2020
    • 6
    • U.K.
    Re: Macbook 820-3787 Backlight Not Working
    Here are some images of the area
      • 21927
      You can post images here if you use the Go Advanced button, then Manage attachments .
        • 21927
        Schematic + boardview - https://www.badcaps.net/forum/showthread.php?t=62268
        • BoardNoob
          • May 2020
          • 6
          • U.K.
          Originally posted by SMDFlea
          Yes, I have all those schematics and board views. I'm hoping for some input no interpreting the data I have.
          Apologies, electrical is a weak area for me.
          • piernov
            • Jan 2016
            • 4439
            • France
            Is it no image, no backlight or both?
            Given the state of the board I assume this doesn't give an image either, but this is very important since no image and no backlight are 2 different issues that have almost completely separate circuits. Also backlight usually depends on image, but not the opposite.
            The inductor L8300 with liquid damage near the LCD connector seems to be damaged so it'll probably have to be replaced. The measurements also seem to point to a failure around L8300, so first thing I'd remove it, clean the dirt on the board and then measure resistance to ground on both pads.
            Also please report the resistance readings with unit prefixes like 1kiloohm rather than 1 000 ohms. A lot of countries use the comma as a decimal separator, and sometimes the dot as thousand separator so it can be quite confusing. (even more when some numbers have a separator and others don't)
            Here I assume that 167,000 Omhs means 167 kiloohms, please confirm.
            • BoardNoob
              • May 2020
              • 6
              • U.K.
              There is an image. When I sign a torch behind the apple logo on the laptop, I can see a dialogue box open.
              I will replace L8300.
              Do you think the connector is bad, or do you think it is finding a short through the L8300?
              Apologies for the use of a comma on numbers, this is a habit of mine. You are correct that when I use a comma, I am separating thousands and not decimals. So yes, the resistance on the capacitors is 167 kilohms. I will edit the original post.
              • emestee
                • Dec 2019
                • 228
                • Bulgaria
                You can't know if the connector is bad without testing it, but judging by the state of the board you should take it off and clean the pads and solder it back anyway before any meaningful testing.
                • BoardNoob
                  • May 2020
                  • 6
                  • U.K.
                  I just read online that L8300 typically blows if the LCD screen, LCD screen cable, or LCD connector short to ground. The advice is to check pins 28/29/30 of the LCD connector with the LCD plugged in. Low resistance means it would blow again.
                  I do get low resistance from these pins, so I think I have answered my own question that I should replace the LCD connector.
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    That's a bit confusing because the measurements + the state of L8300 points toward an issue with the LCD panel power rail, which would prevent any image from appearing. (and since the LCD panel is not powered, it cannot be recognized by the machine, and the machine won't turn on backlight either)
                    The backlight rail (on the other side of the LCD connector on pin 1) doesn't seem to be affected by liquid damage and the measurements sound good.
                    However as I said you have to take L8300 first as it is visibly damaged and there is corrosion that needs to be cleaned there. Once L8300 is taken off you can at least confirm if the short to ground is on the LCD connector side or on U8300 side.
                    You can also inspect the connector on the LCD cable to see if there is any damage there.
                    • Constantinos
                      Macbook Pro A2442 820-02098 No image but has backlight
                      by Constantinos
                      Hi all
                      I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                      He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                      Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                      Obviously, he decided against this and gave it to me so that I could have a crack at it.
                      From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                      08-24-2024, 09:48 AM
                    • francescoranchi
                      MacBook Pro A1909 LCD (no backlight)
                      by francescoranchi
                      Hello Everyone,
                      I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
                      I would need just to make sure that what I know/my reasoning is correct:
                      - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
                      - Seller confirmed its a LCD issue, and not an issue with the...
                      12-04-2023, 06:46 AM
                    • tommy97
                      Apple MacBook A2337 - No backlight
                      by tommy97
                      Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
                      The laptop was tested with fully working screen.
                      PP5v_BKLT_A/B 5V
                      PP5v_BKLT_D 5V
                      PP5V_S2 5V
                      PP5V_SW_LCD 0.4V
                      P5VS2_PWR_EN 1.8V
                      P5VS2_BST_R 8V
                      P5VS2_SW 5V
                      PPBUS_5VS2_VIN 5V
                      PPVOUT_LCDBKLT - Doesn't short 0V
                      FP800 - Both sides 12v
                      BKLT_EN_R & BL_PWR_EN - around 1.8v
                      LP800 0.014V On both sides (should be 12? / no short)
                      UC300 & UP800 Replaced...
                      12-02-2024, 08:26 AM
                    • rcanpolat
                      M1 MacBook Pro 2021 A2485 - No backlight display
                      by rcanpolat
                      I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
                      Here’s what I’ve observed so far:
                      • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
                      • I did some basic resistor
                      08-24-2025, 02:16 PM
                    • Riananyaina
                      MacBook A1708 820-00840-A backlight issue
                      by Riananyaina
                      Hello Everyone ,
                      today I'm coming to you regarding my issue which is no Backlight .
                      I have image on my screen but no light .
                      The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                      First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                      Please find below few informations which can help for the analysis...
                      04-24-2023, 05:03 AM
