820-00840-a 00875-a SMC compatible?
  • daltonjr.
    • Jul 2016
    • 45
    • Austria
    anyone knows if SMCs from these boards are compatible? I have 820-00875-a with bad smc, and a 820-00840-a donor board. They are very similar, same ram amount, 00875 has 2,0 i5, 00840 has has 2,3 i5.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 820-00840-a 00875-a SMC compatible?
    Not sure, 00875 is the 2016 model while 00840 is the 2017 model. They are very close so it may work. RAM and CPU don't matter.
    • NotEnough
      Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
      by NotEnough
      I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
      What I've Tried So Far:
      • Reseated the cables.
      • Reinstalled AWCC and AlienFX services.
      • Attempted BIOS downgrade but no improvement.
      • Inspected ribbon cables for damage.
      • Explored the possibility of BIOS or
      10-19-2024, 01:34 AM
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      08-12-2025, 03:01 PM
    • Deby
      List of compatible laptop motherboards
      by Deby
      This is a list of compatible laptop motherboard information that I have been collecting for some time.
      And it's still ongoing.
      Every time I come across information that a board is compatible with another, I write it down.
      Anyone who wants to, can continue to expand the list.
      Packed in the rar, is an excel table that has additional information.
      Motherboards.rar...
      05-31-2024, 04:34 AM
    • m4a2t0t
      BD35231 compatible replacement
      by m4a2t0t
      Anyone know of a compatible replacement that has an adjustable output? The BD35230 has a fixed output of 1.0V and would be acceptable but I cannot find it anywhere. There is also the BD3523 which has an adjustable output but its also nowhere to be found. I could probably source them from alibaba but I dont have that much time and I dont want to make a huge order.
      Or perhaps you know how the BD35231 can be modified to output 0.95-1.0V? The board does have empty pads for an adjustable IC but Ive only been able to make the output go up.
      Thanks for any help...
      08-28-2025, 08:32 PM
    • taurtnt
      Help identifying AMCH073 regulator or finding a compatible replacement
      by taurtnt
      I’m trying to identify a step-down regulator marked AMCH073. It’s used on the PEX power rail of a graphics card. I can’t find any datasheet or info online.
      Here’s what I’ve observed:
      • It has a QFN-16 footprint, similar to NB670.
      • Pins 1, 2, 15, 16 are connected together and go to the inductor, so likely SW (switch node).
      • Pin 9 is connected to GND, which doesn’t match NB670 (where pin 9 is SW).
      • Pin 8 also seems to be tied to the same GND plane.
      • The chip only says AMCH073, no manufacturer logo or other markings....
      08-24-2025, 03:06 PM
