Macbook Pro A1502 (820-4924-A) beeping, no signs of water damage.
  • agavrilescu
    • Apr 2020
    • Italy
    Hi guys, I am hoping someone can help. I have purchased a very cheap Aand faulty macbook pro A1502 (820-4924-A) to play with and learn a little about repairs.
    Now, the laptop is in great condition internal and external, doesn't seem to have been messed with, however, when plugged in and power button is pressed it starts to chime, continuous 3 chimes.
    I opened the computer and checked the motherboard. I can see on the inside of the motherboard, around U7700 chip (back-light chip?) there was something that caused a short as the interior of the case is melted (see photo).
    The problem is I dont see any obvious damage on the motherboard itself, as you can see in the second image, everything looks quite ok.
    I understand it can be a problem with RAM and CPU, however I would like to exclude anything else before trying to reflow the RAM.
    I have the schematics and board view but I dont know if there is actually a way to test the RAM and CPU. I have done some measurements that to be honest I dont know if I measured the right things.
    PPBUS_G3H = 12.56 V
    PBUS_S0_VSENSE (Q5480 pin 3) = 3.40 V
    PPVCC_S0_CPU = 1.865 V
    PPVTTDDR_S3 = 0.60 V
    PP0V6_S0_DDRVTT = 0.273 V
    L7430 = 1.205v
    Thanks to anyone who can help!
    Alex
  • MobileXT
    • Oct 2012
    • 214
    Re: Macbook Pro A1502 (820-4924-A) beeping, no signs of water damage.
    check the voltage of the RAM if present. If present then reflow all the RAM chips.
    • rounin
      MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
      by rounin
      Device Information
      • Model: MacBook Pro 14” M1 Pro (A2442)
      • Logic board number: 820-02443-05
      Original Issue
      The device suffered liquid damage, causing a short circuit on the logic board.
      Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
      Work Performed
      Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
      Current Status
      • When powered on, the screen shows support.apple.com/mac/restore....
      10-20-2025, 11:15 PM
    • Ugur87
      MacBook Air M4 A3240 Brand New Water Damage no Image
      by Ugur87
      I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
      08-28-2025, 01:09 PM
    • mon2
      A1466 Macbook Air (Liquid damage repair)
      by mon2
      Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
      Macbook AIR Model A1466 Diagnostic 09-01-2021
      Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
      Problems & Resolutions
      1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
      09-01-2021, 09:31 AM
    • TimSinger
      MacBook Pro M4 16" A3403 on the table with water damage
      by TimSinger
      Hi guys,
      I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
      I attached a photo of the missing cap. It's on the bottom side of the logicbard.
      I am very thankful for your replys.
      Thanks in advanced and best regards from Hamburg Germany...
      07-13-2025, 11:12 AM
    • gbuniva
      MacBook A1502 (820-3476-A) Repair case with solution
      by gbuniva
      Hi everyone, I want to share my tech experience with a MacBook Pro A1502 late 2013 that won´t turn on.
      The computer arrived dead, when connected to Magsafe no lights on the connector.
      Here some Measures at some testpoints on de LB 820-3476-A :
      PP3V42_G3H 1.7V
      PPBUS_G3H = 0V
      PPVBAT_G3H_CHGR_RE = 0V
      PP3V3_S5 = 0V
      PP5V_S4 = 0V
      P5V1_SW = 5.5V
      PP3V3_S0SW_SSD =0V
      PP3V3_S0SW_SSD_FET =0V
      PPDCIN_G3H_INRUSH = 16.10V
      PPDCIN_G3H_CHGR = 16.10V
      PP5V_S5 - 0v
      PP3V3_S5 - 0v
      PP3V3_SUS - 0V
      PM_RSMRST_L - 0v...
      04-09-2025, 07:11 PM
