lenovo yoga 3 14"
  • manubali
    • Feb 2017
    • 23
    • New Zealand
    lenovo yoga 3 14"
    hi, i have a Lenovo yoga NM-A381, the main issue is that it will turn on first time when i disconnect the battery and power it on with adapter, after that when i shut it down, it won't boot again, the fans will spin for few seconds then they stop and keeps on looping. this machine turns on itself when power is connected(just like MacBooks) when power is connected for first time, all the voltages are fine, but after shut down and pressing power button, "EC_ON" jumps from 3.3v to 3.6 to 3.8v and this causes "+3VLP" to jump to 3.6 to 3.8v aswell and "+3VALW" drops to 2.4 to 2.7v.
    i usually repair MacBooks so don't have much experience in laptops, what should i try next?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: lenovo yoga 3 14"
    Make sure your multimeter batteries are good. +3VLP should never go to 3.8V, it is what's causing EC_ON to go to 3.8V as well. If you are 100% sure +3VLP indeed goes to 3.8V, then PU201 is probably bad.
    • sopik78
      • Nov 2013
      • 519
      • Czech Republic
      Any update of this? I have the same problem with the same board, the only differnce is the +3VLP is still +3,2V. +3VALW goes to 2,25-2,7V.
      • sopik78
        • Nov 2013
        • 519
        • Czech Republic
        So although I still dont understand why, the solution for my case is to change U101, after that laptop works..
        • Sephir0th
          • Oct 2020
          • 1289
          Good evening, i have the Same model with a similar issue.
          MOD Edit: Link to schematic - https://www.badcaps.net/forum/showthread.php?t=65129
          History: bad GPU- & RAM-Controller. Gate from LowSide mosfet was shorted to ground on both ICs.
          After replacing both ICs i can do a "Cold Boot" (battery and Adapter disconnected and reconnected before) and It's booting to OS without Any issue. but if i shut it down and try to Power it on Second time, i get No Backlight, No Display, No BIOS (CapsLock-test), dimmed LEDs, etc.
          In my case the +3VLP is dropping from 3,3V to around 2,5V. i Wonder if the Voltage of B+ (thought it Has to be 19V) is okay? If Yes, i believe i have to replace PU201 too... The +5VLP Rail is working fine with Same Input Voltage.
          The weirdest Part is, it is working after Cold Boot, although i never get a PWRGD from this IC... o.O
          FairRepair on YouTube
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            Please confirm
            Ldo is not dropping
            If ldo drops in any case , ic will not go to next step
            Your output is dropping due to capacitor leakage or missing after coil and feedback value is not ok
            I am not an expert I think it is nvdc technology ,b+ feeder to every section as an input voltage , 8v approximately
            • Sephir0th
              • Oct 2020
              • 1289
              I can confirm the LDO isn't dropping, but The Phase on the Coil. And yes, It's NVDC, my first Laptop with a Charging Circuit Like this. Thank you, i'll Check the Caps First.
              • odemontealto
                • Jan 2014
                • 13
                • SPAIN
                Tank you very much. I changed U101 and the laptop worked perfectly. It got very hot and must have disrupted the super I/O. I do not understand very well why it affected the + 3valw source ... This voltage did not rise more than 2.7v. and the power led was continuously blinking. I was desperate with this fault.
                We technicians exist because engineers need heroes too
                • Sephir0th
                  • Oct 2020
                  • 1289
                  Then you were more lucky than i was. While troubleshooting Once the Controller died completely and shorted 5V, EC and unfortunately PCH too. Now the Board is Just for spares...
                  • introMac
                    • Aug 2016
                    @sopik78
                    You are a life saver. Thank you.
                    After removing U101 to confirm that the board will turn back on, it does!
                    • mon2
                      • 14673
                      U101 = USB Load Switch.
                      Respectively, if removing this load switch works for you, this implies the load switch is defective and was shorted.
                      By removing U101 off the board, that local USB port or ports will no longer function since Vbus is no longer being passed through onto the connector(s).
                      You should seek out a replacement so that port will be functional once again.
                      • introMac
                        • Aug 2016
                        I appreciate the concern. As mentioned I removed U101 to verify that it was causing the issue.
                        A replacement IC has been ordered and will make the replacement when arrives.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          Have you replaced U101 yet?
                          If it fixed the problem, would you please provide a URL for the replacement IC
                          better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                          • pfrcom
                            Oldbie
                            • Jun 2006
                            • 1230
                            I tried removing U101
                            Didn't improve things unfortunately
                            It still won't start with battery connected
                            Only improvement it'll now start with power button, instead of having to use Novo button
                            Prerequisite still have to disconnect battery, then hold button while switching charger on
                            Win10 does detect a USB key though, a function I expected to lose with removal of U101
                            Everything else still the same as described in my original thread:
                            https://www.badcaps.net/forum/showthread.php?t=121843
                            • AWolfEco
                              • Dec 2023
                              I legit signed up just to try and figure out what in the world is causing this stupid issue and why Lenovo hasnt taken care of it by now...
                              • mon2
                                • 14673
                                It is a long thread. Which issue are you facing ? Usb port is defective? Or another fault?
                                  Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                  This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-07-2024, 05:00 AM
                                  Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                  This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                  Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                  Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                  This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
