Dell E5470 short in processor? LA-C831P
  • seanc
    • Nov 2008
    • 1319
    Reaching out for any thoughts as I'm stumped.
    I have two identical failed laptop motherboards. Both sport an Intel i7-6820hq.
    Both boards failed in the same way, just went 'dead' with a smell of burning, not shorting the charger, but the inductors get very hot when plugged in to the laptop power supply.
    An obvious failure on both was PU603 (Vishay SIC530 Manual) appearing burnt at the Vin section and Vin showing short to ground.
    Removing PU603 removes that short, but I'm left with a short to ground on the Vswh side which the datasheet calls "Switch node of the power stage". I think that connects to the processor?
    I cannot find the short and I've pretty much resigned myself to it being the processor.
    The first board I did a poor job at removing PU603 so I have essentially consigned it to scrap and dismantled that bit by bit looking for any changes.
    On that board I have removed:
    PU602, PU605, PU606 (all SIC530), no change.
    A bank of capacitors next to PU604 and PU605 that appeared shorted.
    PU601
    No amount of checking/removing surface mount caps or other chips will lead me anywhere close - the problem is seems confined to any section with components labelled x6xx so I think that's all one related circuit. My last thoughts are the capacitors on the rear side under the processor.
    Does anyone have any thoughts? Pictures of the second board with only PU603 removed.
    If anyone wants clearer photos of a section, please let me know - I'm struggling with the phone camera.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Dell E5470 short in processor? LA-C831P
    What's the exact resistance to ground where you think there is a short to ground?
    • seanc
      • Nov 2008
      • 1319
      Between gnd and vswh 03.5ohms on the 200 ohms setting - admittedly I've done most of my testing on the 2000 ohms setting where it just shows 003. Happy to be proven wrong, especially if it's because I screwed up the first board.
      • piernov
        • Jan 2016
        • 4439
        • France
        It's a little bit on the low side as I usually see 6 ohms on Skylake, but it's most likely not a problem.
        Doesn't mean the CPU is fine since newer CPU rarely survive when something goes wrong on CPU VCore, but it's not shorted.
        • seanc
          • Nov 2008
          • 1319
          I'll replace PU603 on the second board with another new one and see what happens... the first just turned on for a second and then off.
          • seanc
            • Nov 2008
            • 1319
            Replaced PU603 on the second board, same symptoms unfortunately, turns on, then off.
            • seanc
              • Nov 2008
              • 1319
              I went over the board again today and noticed that the replacement SIC530 had a ground short on a pin that should have no connectivity.
              I replaced it and a capacitor next to it (it looked tested open circuit, it was) with one from the scrap board, but sadly no change the power light comes on, then almost immediately off, sometimes it stays on a bit longer.
              I measured all of the caps under the processor on the reverse of the board and all show ~2.6ohms or higher depending on which side of the processor I measure.
              What has changed, is that there is no longer a short across the inductors after p602, 603, 605, 606 - 3.4ohms now.
              I suppose the next steps are to look for voltages - what should we expect at PU603?
              • pepegotera454
                • Jul 2014
                • 15
                • andorra
                You have checked if it is a direct line to the CPU
                • seanc
                  • Nov 2008
                  • 1319
                  I'm unsure of which points to check - any suggestions?
                  • chris1379
                    • Apr 2015
                    • 15
                    Did you ever find the problem? I have a very similar board with the same problem. Mine is an LA-C841P with PU602 burnt.
                    • seanc
                      • Nov 2008
                      • 1319
                      Nope, still got the 2 dead boards and an number of slightly different donor boards. Hope to try and investigate again when time allows.
                      • mantza
                        • Sep 2020
                        • 36
                        • GREECE
                        did you find any solution? do you think the cpu is shorted?
                        • mazenkataya
                          • Dec 2021
                          • 45
                          • lebanon
                          any news regarding this dell baord issue with pu 602 And pu 603
                          i changed ics after short in charging line but still have power issue only showing white light on power button
                          • mauri1990
                            • Jun 2021
                            • 5
                            • argentina
                            got the same board and same problem in those ics pu603 in my case. board try to start then power goes off ( aparently no shorts to ground), i was checking voltages and 3valw and 5valw are present, 1,1v , something is pulling off the board. already replaced pu602 and 603, no changes
                            • mon2
                              • Dec 2019
                              • 14660
                              Post #2.
                              • mauri1990
                                • Jun 2021
                                • 5
                                • argentina
                                Originally posted by mon2
                                Post #2.
                                1.5 ohms on both coils, looking with thermal camera when you press the power button cpu try to start , current goes up to 300mA after less than a second then it shutdown but the light (next to power button) keeps on
                                • mon2
                                  • Dec 2019
                                  • 14660
                                  Power may be going off for other reasons including a defective current loop circuit.
                                  Remove all power. Meter in resistance mode. Measure the resistance between pins # 1 & # 2 on the charger IC @ PU801. We are wanting to check the total current sense path resistance and compare to the values showing in the schematics. This measurement should be ~100 ohms since the series mosfets in the path will be off.
                                  Confirm you have ~0 ohms if tracing from the actual pin on the charger IC to the mosfet on the same trace. Check both pins. Need to be sure there is no disconnect in this region of the board.
                                  • retrorepair2
                                    Dell E5470 LA-C631p - Short removed now turns on but no post/display
                                    by retrorepair2
                                    Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
                                    Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
                                    09-25-2025, 07:12 AM
                                  • DynaxSC
                                    Extreme High Current & Low Voltage Short Killer ??
                                    by DynaxSC
                                    Hi Folks
                                    I'm looking for a extreme high current short killer solution for a reasonable cost.
                                    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                    After taking off the socket, the shorts dissappear again.
                                    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                    10-15-2024, 10:13 AM
                                    DELL Latitude E5470 Notebook 5000 Specification for Upgrade or Repair
                                    This specification for the DELL Latitude E5470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E5470 boardview and E5470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                    09-07-2024, 12:40 AM
