Lenovo ideapad 500 power off after 3 sec
  • meraklinetx
    • Apr 2019
    • 60
    • turkey
    I have lenovo ideapad500 with the mother board of la-c851p it was working ok but when i open it and clean fan and replace thermal compaund , the system is not working anymore, the problem is :
    When i press power button, the system is turns on with no display and fan does not spin and after 3 sec it powers off itself, i remove all battery, reset bios , préss power button about 30 sec . But still same, what might be the problem ?? What you advise
  • peste
    • 13585
    • ROMANIA
    Re: Lenovo ideapad 500 power off after 3 sec
    remove everything, and from the beginning, maybe you made a short one! remove (wifi, cd, battery, etc.) and turn on the board, see what happens.
    • meraklinetx
      • Apr 2019
      • 60
      • turkey
      Dear peste, thanks your quick answer, i did what you told, the laptop is fixed now, when i remove the heatsink the laptop worked ,i think the problem was heatsink were contacting with the capacitors over gpu chip, (but the interesting point was the heatsink were coated with black protector bands) so i apply extra band to over the capacitors on gpu , applied new thermal paste again and installed the heatsink back, now the laptop is working properly, thanks for your advice and help
      • ravi_1617
        YY Solutions
        • Jan 2012
        • 348
        • India
        Hi .same board , Shutdown at Lenovo logo. Than if i press power button again don't start until disconnect adapter .without ram stays on .board has GPU too more thing observed CMOS battery is draining very fast.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          check voltage on power button and resistance and voltage on RTC battery
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 348
            • India
            Thanks for replying
            Just checked.
            3.275 volts before on
            2.966 during on
            3.216 after shut off
            CMOS shows 60 ohms
            • ravi_1617
              YY Solutions
              • Jan 2012
              • 348
              • India
              Where to start from . Thanks
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Since you are getting display everytime, i dont think its RTC issue. I'll bet for bad kbc and suggest to replace it.
                • ravi_1617
                  YY Solutions
                  • Jan 2012
                  • 348
                  • India
                  Hi ,Problem was of adaptor, user was using 2.25 Amps.Has to be 3. Amps above.
                  • Dr.d
                    Help please..Lenovo ideapad 5 14itl05 power and charging problem
                    by Dr.d
                    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                    04-05-2024, 11:48 AM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • gleniu
                    Lenovo IdeaPad Gaming 3 15ACH6 - no power
                    by gleniu
                    Hi, I have a problem with a Lenovo IdeaPad Gaming 3 15ACH6 laptop. My nephew asked me to replace the charging port because the laptop wasn't charging. This issue had happened in the past, so I knew that replacing the port was only a matter of time. Until now, my nephew managed to deal with the problem using a temporary solution: bending the positive metal tabs inside the port with a thin tool. However, this had stopped helping for a while. Today, I replaced the port – and to my surprise, after the replacement, nothing happens when I plug in the charger: the power LED doesn't light up, the laptop...
                    10-27-2025, 01:13 PM
                  • rabsonnjala
                    LENOVO IDEAPAD 100 works only on bench power supply
                    by rabsonnjala
                    Hie I have a Lenovo laptop
                    Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                    it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                    below are my readings
                    with the original charger only
                    JBATT1
                    PIN1 0.22V
                    PIN2 0.22V
                    PIN3 0.45V
                    PIN4 0.45V
                    PIN5 O.43V
                    PIN6 0V
                    PIN7 GND
                    PIN8...
                    11-20-2021, 08:32 AM
                  • acata
                    Lenovo Ideapad slim 3 not power on
                    by acata
                    Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
                    And the consumer asked for reinstalling OS.
                    I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
                    Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
                    Check the main power rail for 20v input ok
                    No amper input from Power supply 0.013a
                    Mosfet PQ201 20v and 26v ok.
                    3.3v exist
                    1,8v exist
                    5v exist
                    12v from baterai exist....
                    09-30-2024, 09:42 PM
