Laptop screen shortening the laptop motherboard
  • Will19931
    • Jul 2019
    • 10
    Hi there, basically I'm in a process of fixing my gigabyte aero 15, and I encountered a really weird problem, which is when I plug the EDP screen cable to the screen it shorts the whole motherboard, basically no volts, nothing, if you press the power button nothing happens, but when you unplug the screen it works like nothing happened, just to mention I'm not sure about the state of the screen, probably needs a replacement, but I just wanted to know before I replace with a new screen, if it's possible for a screen to short the entire motherboard, or is actually the main chip protecting the motherboard from damage, and also instead of the screen could be possible the edp cable be the responsible for this issue?
    thanks and stay safe everyone.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Laptop screen shortening the laptop motherboard
    The backlight of the display can cause that, so measure the resistance to ground on the backlight pins of the LCD connector. Both on the LCD itself (LCD cable disconnected) or on the motherboard's connector with LCD plugged (and compare with LCD unplugged) in if possible, so that you confirm if the issue is with the LCD or with the cable.
    • Will19931
      • Jul 2019
      • 10
      Hi there, sorry for the late reply, hope everything is okay, so I measured with the laptop off and on and on the cable i had only 19v not 3v, but on the actually connector i got the both signals, anyway i bought a new screen and it still doing the same thing , which seems to be an issue with the cable
      • Stunt
        Hp Laptop Stuck on Hp protected by hp sure start screen
        by Stunt
        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
        screen that's it and stuck there. I left it until the following day and i still...
        09-02-2025, 01:51 PM
      • jean luc ferre
        laptop hp g72 b52sf screen problems
        by jean luc ferre
        on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
        the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
        i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
        i don't understand the reasons of the white stripe at the bottom of the screen below the task...
        06-07-2025, 03:27 PM
      • Geeker007
        Friend messed up my laptop motherboard while working on my bench
        by Geeker007
        Hi All,
        So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
        So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
        I have not tried putting...
        06-16-2025, 01:40 PM
      • Username338
        Laptop BA92-09470B motherboard schematics
        by Username338
        Thank you for deciding to read this topic!
        Laptop: NP700Z3A-S02RU
        Motherboard: BA92-09470B
        I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
        I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...
        03-09-2025, 03:52 PM
      • Admin
        Other Useful Threads - Laptop Screen Compatibility, Useful ICs, BGA Chip Suppliers, NVidia bumpgate
        by Admin
        Some sticky topics have been moved to this thread:
        - finding a compatible laptop screen with LED-backlight.
        Most Common ICs - a list of the most common ICs (Integrated Circuits) required for repairing a laptop
        MOST COMMON IC FOR LAPTOP YOU SHOULD HAVE IN STOCK
        Let's Talk About BGA Chip Suppliers - anyone who repairs computers at component level has had to order chips from China at some point. Large BGA chips like graphics chips, chipsets and now CPUs are in increasing demand, due to their...
        12-27-2023, 03:43 AM
