HP 250 G2 wifi problem
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    Dear friends, I would to ask for help with strange problem.
    HP 250 G2, MB OSAMU2_BT_HPC MV_MB_V1, blank screen with 2 blinks on caps lock. After reflashing BIOS laptop starts correctly, boots to win 10, but wifi doesn't turn on. Wifi button on keyboard lights orange. Wifi adapter correctly installed and changed for several other models, but still can't turn on. System reinstalled as well.
    I don't understand why I can't turn on adapter when system can see it and has no conflict.
    Any suggestion what to do?
  • peste
    • 12959
    • ROMANIA
    Re: HP 250 G2 wifi problem
    still try other bios ..
    • kiraro
      • Jan 2016
      • 177
      • North NY
      search for hp wireless utility program you can activated through that if button doesn't work
      • piernov
        • Jan 2016
        • 4437
        • France
        Can happen when using a WiFi card not allowed by the BIOS (even after whitelist removal). If you cannot find a BIOS/WiFi card combination that works, you can mask the wireless disable signal pin (pin 20 on miniPCIe) on the card with some tape.
        • sopik78
          • Nov 2013
          • 517
          • Czech Republic
          Many thanks to all.
          Have tried 2 other bios dumps so far but with no succes.
          Piernov - pin 20 really helped!
          • Jesse James
            • Sep 2018
            • 95
            Wow I ran into this many times and didn't know this trick.
            Many thanks
            • frica
              • Nov 2017
              • 37
              • Spain
              +1
              • Conste
                • Oct 2018
                • 235
                Did you try the keyboard command to activate wifi?
                Had the same issue with an MSI 16F2 based unit
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Chris_p
                  Msi mag b660 wifi ddr4 no power problem
                  by Chris_p
                  Hello I have a msi mag b660 wifi ddr4 board that I’m unable to get to power on. Ive bought it off a auction site so no history on the board and no warranty, got it super cheap, trying to make a budget build and it backfired.
                  I’ve tried to jump the power pins and also hook up the power switch from my case and no signs of life.
                  i have jump the power supply while not connected to the board to confirm power supply is good and it is.
                  I have installed the cpu, ram and graphics card than removed them one by one to rule out them as a fault.
                  im...
                  09-21-2024, 01:31 PM
                • howardc64
                  M557-G0 no WiFi/Bt no WIFIVendor file?
                  by howardc64
                  Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
                  • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
                  • Service Menu shows many Bt/Wifi info missing
                  • Vizio app shows no WIFIVendor file
                  Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
                  • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
                  10-15-2024, 01:12 PM
                • ugamazing
                  820-00850 & 820-01949, No WiFi *In Recovery*
                  by ugamazing
                  I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
                  1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
                  2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
                  01-25-2023, 05:39 PM
                • helpmepleasethanks
                  Thinkpad T440P bios repair after WIFI whitelist mod
                  by helpmepleasethanks
                  As per the the rules, here are the specifications of my laptop :
                  • Make and model number : Thinkpad T440P
                  • Serial number (S/N) : PB-03A7V7
                  • Model type - Model (MTM) : 20AW-S2N800
                  • Bios version : 2.50 (not 100% sure, that's what I remember)
                  Here is the problem, and the events leading to it :
                  1. Upgrade screen, keyboard, trackpad, RAM and CPU
                  2. Reboot and use the laptop for a bit : everything is working fine
                  3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
                  4. Boot up the device : bios warning, as expected
                  5. Shutdown the device again (no power)
                  6. Connect the 8-pin clip of a CH341a
                  01-09-2025, 12:09 PM
