Sound Problem Workstaion HP 4600
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    Hi all,the sound works really well for 2 maybe 4 hours since it starts noise so you get mad but if you restart the computer then works as it should.I have already changed two sound cards already but it did not help I think the sound in the motherboard is not working as it have to be
    the motherboard is HP XW4600 any help are very aprecieted thank you
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Sound Problem Workstaion HP 4600
    as u use external sound cards the internal sound card is not in use
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      did u put output to external card?
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        Hi thank you for the answer the internal sound card is not working too so i have to use external card and of course outpout to it
        • hugocarmo
          Panasonic TX-24A1UN CRT Sound and Input problem.
          by hugocarmo
          Hi.
          I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
          It is imaculate inside, almost no dust or debris inside.
          The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
          So I started to look for a service manual, I found one, and started from the beginning.
          Most of the times the caps are the problem so I orderer all the caps for all boards,...
          04-26-2025, 07:45 PM
        • computeka
          Macbook Air A2337 820-02016-07 No sound problem
          by computeka
          How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
          05-08-2024, 10:26 AM
        • Alija
          sound problem on my dell latitude 5300 2 in 1 laptop
          by Alija
          I have a sound problem on my dell latitude 5300 2 in 1 laptop.
          Sound was working on the laptop and I had 2 Intel drivers and one more. When I turn on a song on You Tube, there is no sound, I uninstalled the drivers and tried to install them again, but now in the device manager the sound card is not visible, it only has Intel HD
          Please help me
          08-02-2022, 12:31 AM
        • cazi1001
          Samsung Galaxy A22 - strange problem with sound / speaker
          by cazi1001
          I have a Samsung Galaxy A22 5G with a strange error image.
          If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
          If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
          If I listen music via Youtube, even the upper or lower speaker don't work.
          If I switch louder or quieter, the sign on the screen show me a headphone.
          If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
          Does anyone have any ideas, what the problem could be?​
          02-10-2024, 09:16 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
