HP Pavilion 15-P (Y11A) no power, S5_ON not present
  • classicandy
    • Apr 2018
    • 308
    • Nigeria
    Re: HP Pavilion 15-P (Y11A) no power, S5_ON not present
    I haven't been able to get a 90W adapter yet but I've tested it with a 65W adapter and yet, it hasn't worked.
    Could the charging I.C be faulty? Its a new one I bought from china that I put on it.
    • Techtiger
      • Oct 2014
      • 1602
      • france
      Do you have a DC Power LAB ?
      • classicandy
        • Apr 2018
        • 308
        • Nigeria
        If by "DC Power LAB", you mean "DC Power Supply", I don't have for Laptops. Mine is for phones and Tablet PCs with a max of 15v.
        • kiraro
          • Jan 2016
          • 177
          • North NY
          you can solve this problem with adding resistance (330k) between AD_ID (pin 5 "DC-IN CONN" CN20) and +VA_AC (pin 1-2 VDD "DC-IN CONN" CN20) .
          but you disconnect the AD_ID from the connecter (just move a little bit the plastique clip and you can retrieve the AD_ID cable ).with this way even a 45w or 60w works, you just need a 19v input no matter the power of the charger because the motherboard will see permanently like a 90w charger
          • classicandy
            • Apr 2018
            • 308
            • Nigeria
            okay, Thanks for the Tip.
            But this will mean, by-passing the restriction of using a lower power adapter.
            Anyways, I was able to get a 120W adapter and yet, it didn't work. Means the charging section of the board still has a problem that needs to be fixed.
            I know a 65W adapter should still work with this motherboard. So, the board is still faulty. Any ideas on what next to be done?
            • kiraro
              • Jan 2016
              • 177
              • North NY
              #26
              check resistance R298,R304,R294
              • classicandy
                • Apr 2018
                • 308
                • Nigeria
                #27
                R298 = 99.5 ohms
                R304 = 10.79K ohms
                R294 = 9.15K ohms
                R279 = 9.20K ohms
                • kiraro
                  • Jan 2016
                  • 177
                  • North NY
                  #28
                  what voltage you get on AD_TYPE (R294),pin67 (U11),also make sure you are using a good connector cable ,sometimes the middle pin for the cable connector for DC_IN it's damaged and no continuity to the board. try the tips a mensionned before if there is a problem with the cable .
                  • classicandy
                    • Apr 2018
                    • 308
                    • Nigeria
                    #29
                    R294 = 0.60v
                    Pin 67 [U11] = 0.60v
                    Connector cable is good. I've checked with other known working cables too. No continuity so far.......
                    Resistors at the charging IC area seems to read normally too.......
                    I'm pretty much confused on what to do on this motherboard currently
                    • kiraro
                      • Jan 2016
                      • 177
                      • North NY
                      #30
                      check R279 and R284 if exist .
                      • classicandy
                        • Apr 2018
                        • 308
                        • Nigeria
                        #31
                        R284 doesn't exist but R279 exist [same as schematic]. Voltage on R279 = 0.69v
                        • kiraro
                          • Jan 2016
                          • 177
                          • North NY
                          #32
                          you should get 3v through R279 for signal"ADAPTER_SEL_EC" that mean you have select 90w charger type for DIS motherboard , +3PCU->R279(10k)->ADAPTER_SEL_EC(3,3v), For uma motherboard ADAPTER_SEL_EC = 0v that mean 65w charger type through R284, so ADAPTER_SEL_EC should be 3,3v or 0v, in this case you should get 3,3v so check r279 value and check +3pcu on r279 .
                          • classicandy
                            • Apr 2018
                            • 308
                            • Nigeria
                            #33
                            Finally, I've fixed it. It turns out that there was a partial short between the Gate and the Drain of PQ33. After replacing it, the motherboard started working normally again.
                            Thanks to everyone who contributed
                            • classicandy
                              • Apr 2018
                              • 308
                              • Nigeria
                              #34
                              Everything is now okay......... Thanks for the assistance. I really appreciate...
                              • phamthai2503
                                • Dec 2015
                                • 4
                                • Viet Nam
                                #35
                                starting the repair process I always measure and check the input source at the G pins of 2 Mosfet PQ33 and PQ20
                                  HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                  09-12-2024, 03:44 PM
                                  HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                  HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                  HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
