HP Pavilion 15-P (Y11A) no power, S5_ON not present
  • classicandy
    • Apr 2018
    • 308
    • Nigeria
    I have this HP Pavilion 15-P (Y11A) with no power either through Battery or AC adapter. S5_ON is not present.
    Initially, there was a partial short on PD10. After replacing PD10, short was gone. Now, 5VS5 is present, but 3VS5 is not present.
    Please, what can be done?
  • classicandy
    • Apr 2018
    • 308
    • Nigeria
    Re: HP Pavilion 15-P (Y11A) no power, S5_ON not present
    Also, no voltage at Pin 1 and Pin 3 of PQ20.
    I have replaced PQ20 with a known working one, while the one i removed is working on another board too.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3599
      • slovakia
      must i search for schematic or u upload it here?
      • Techtiger
        • Oct 2014
        • 1602
        • france
        first check the voltage of PU1 pin 20 5 4 6 ? Gate of PQ20 need 24V to by pass voltage to PR211
        • piernov
          • Jan 2016
          • 4435
          • France
          White LED next to AC adapter connector?
          • classicandy
            • Apr 2018
            • 308
            • Nigeria
            I'm sorry, here it is
            • classicandy
              • Apr 2018
              • 308
              • Nigeria
              PU1
              Pin 20 = 20.0v
              Pin 5 = 2.95v
              Pin 6 = 2.68v
              Pin 4 = 0.00
              • classicandy
                • Apr 2018
                • 308
                • Nigeria
                Hi, I don't think i understand what you mean...
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  Originally posted by classicandy
                  PU1
                  Pin 20 = 20.0v
                  Pin 5 = 2.95v
                  Pin 6 = 2.68v
                  Pin 4 = 0.00
                  BQ24738 pin 4 ACDRV is 0V means PQ20 Voltage will not flowit shoud be 24V, pin 4 of PU1 impedance ? PQ20 Gate & Drain impedance ?
                  • classicandy
                    • Apr 2018
                    • 308
                    • Nigeria
                    I don't have an Oscilloscope to measure the Impedance. Any way around that?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      You dont need an oscilloscope to measure impedance. Just do it with your multimeter.Btw, what@piernov means by asking white led is "whether the light on dc jack is glowing white or not"
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        Tests it with multimeter
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          You said 5VS5 is present so 19V power rail +VIN should be present.
                          • classicandy
                            • Apr 2018
                            • 308
                            • Nigeria
                            Ok, No white light. But it does shows Amber led when the battery and AC adapter are connected. It doesn't charge, just shows the Amber led.
                            • classicandy
                              • Apr 2018
                              • 308
                              • Nigeria
                              Please, I need help with this. How do I test with Multimeter to get the Impedance?
                              • classicandy
                                • Apr 2018
                                • 308
                                • Nigeria
                                I forgot to mention, 5VS5 is only present when Battery and AC adapter are connected. +VIN is 14.65
                                Here is my readings [with Battery only]
                                PQ20
                                Pin 4 = 14.20
                                Pin 1 = 14.50
                                Pin 3 = 14.65
                                PU1
                                Pin 1 = 14.65
                                Pin 2 = 14.65
                                Pin 3 = 14.62
                                Pin 4 = 14.54
                                Pin 5 = 0.00
                                Pin 6 = 1.16
                                Pin 20 = 14.20
                                PL8 = 15.23
                                • Techtiger
                                  • Oct 2014
                                  • 1602
                                  • france
                                  Set your multimeter to the highest resistance range available. the Greek letter omega (Ω), or sometimes by the word “ohms.”
                                  • classicandy
                                    • Apr 2018
                                    • 308
                                    • Nigeria
                                    I think that's just me measuring their resistances.
                                    PQ20
                                    Drain = 84k ohms (initially started dropping from Mega ohms)
                                    Gate = 120k ohms
                                    PU1
                                    Pin 4 = 141k ohms
                                    • classicandy
                                      • Apr 2018
                                      • 308
                                      • Nigeria
                                      Ok so, I didn't even take into account that I was using the wrong charger. The board is DIS and the recommended charger is 90W meanwhile I'm using a 45W charger.
                                      I've just requested for a 90W charger. I'll post my findings when I receive the right charger.
                                      • classicandy
                                        • Apr 2018
                                        • 308
                                        • Nigeria
                                        After working on the system with Battery only, I've been able to get the system to power On successfully. I haven't gotten the required 90W adapter yet. It's still not powering On with the 45W adapter.
                                        It turns out two resistors were missing PR128 and PR134. After replacing those resistors, it powered On with Battery.
                                          HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 03:44 PM
                                          HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
