Lenovo IdeaPad s340 burned motherboard ?
  • Mike94990
    • Mar 2020
    • 29
    • Italy
    Hi guys, i have a big problem with a probably burned motherboard (Lenovo IdeaPad s340 )...
    I accidentally forgot to remove the battery while installing an SSD and a small screw fell on the motherboard.
    I think that only one component is burnt but i don't know what is it (i can read L501 but i'm sure it's PL501 because i see another motherboard on ebay)....
    Can someone help me understand what it is?
    I can't find anywhere what PL501 is....
    This laptop is basically new and i want to repair it .
    Here some photos:
    PS: I'm not very good at English, I apologize if there are grammatical errors XD
  • peste
    • Dec 2016
    • 13656
    • ROMANIA
    Re: Lenovo IdeaPad s340 burned motherboard ?
    in this case I think it is L501, make a comparison with other similar parts on the motherboard.
    • Mike94990
      • Mar 2020
      • 29
      • Italy
      Thanks for your reply!
      I just found the same motherboard for sale on ebay (attached) and the component is PL501.
      I would like to know what it is so i can buy this piece or replace it with something equivalent.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        oh god. it is COIL u can use any coil of same size. u can even make bridge for testing
        but first check both side of board pads for short
        • Mike94990
          • Mar 2020
          • 29
          • Italy
          ok, i'll check the other side of the board...
          can you tell me how can i find out the size of this coil? (for size do you mean the physical size in millimeters?)
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            other side?
            i mean both pads where was connected that coil.
            u can use ANY size that fit
            • Mike94990
              • Mar 2020
              • 29
              • Italy
              other side?
              something like this? :
              https://it.aliexpress.com/item/32691809266.html
              how many henry? (I hope to understand you )
              • tomodachi
                • Apr 2012
                • 612
                • Turkey
                it can be easily found on any scrap motherboard, just replace it with same size of coil, not big deal since its placed on +B rail
                • Mike94990
                  • Mar 2020
                  • 29
                  • Italy
                  Thank you guys, you are the best!
                  I'll try to fix it and i hope it work!
                  • Mike94990
                    • Mar 2020
                    • 29
                    • Italy
                    And.... nothing, the motherboard is definitly dead.
                    I used the component from another motherboard and it turn on for some seconds then turn off (and some weird noise from the speakers).
                    In the end it didn't toun on again and it is dead...
                    I think it's the end of this sad story
                    • peste
                      • Dec 2016
                      • 13656
                      • ROMANIA
                      as i see, i think you made a short between the l501 and the first capacitor next ... check .. i hope to cheat ..
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3628
                        • slovakia
                        damn dude. u cannot even solder? u shorted that rail to gnd like peste wrote
                        offcourse no flux
                        • Mike94990
                          • Mar 2020
                          • 29
                          • Italy
                          I checked and there is no short between the component and the first capacitor.
                          In the photo you can't see it well...
                          • Mike94990
                            • Mar 2020
                            • 29
                            • Italy
                            offcourse no flux
                            Where did i shorted that rail to gnd ?
                            the component and the capacitor aren't connected!
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3628
                              • slovakia
                              for me it looks 100% shorted. u did not use flux
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                its shorted you soldered the coil not clean because other side touches the side of caps
                                • Mike94990
                                  • Mar 2020
                                  • 29
                                  • Italy
                                  i'll try to remake it hoping that it's not totally burned.
                                  • peste
                                    • Dec 2016
                                    • 13656
                                    • ROMANIA
                                    use flux paste, otherwise the solder does not come out ok, check that you do not have short, with luck it may be ok.
                                    • Mike94990
                                      • Mar 2020
                                      • 29
                                      • Italy
                                      A little update:
                                      ---I solder it again: i know that the result is a bit ugly (i can't go out from home because of coronavirus, so i can't buy flux paste) but the conductive rail under the component is practically destroyed, so i solder it with the rail on the top right side of the component (IMG 1).
                                      ---I measured the voltage between the PL501 and gnd and it is 12.5V (as schematics says)
                                      ---I try to turn on the pc without ram and ssd: it worked the first time (IMG 2), than i try to insert ram and ssd and it turn on (black display, only light from the power switch and nothing else)
                                      What can i do now?
                                      PS: how can i check if the three capacitors above the component are ok? maybe there is some problem there...
                                      • ktmmotocross
                                        Boardkiller
                                        • Feb 2014
                                        • 3628
                                        • slovakia
                                        just measure rezistance on both side of capacitors to ground.
                                        if u dont have ram inserted and laptor start, than u must have ram on board, so try to remove inserted ram
                                        check if u have 1.2V on pl502
                                          Lenovo IdeaPad S340 Notebook S Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad S340 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S340 boardview and S340 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S340...
                                          09-06-2024, 03:30 PM
                                          09-06-2024, 03:21 PM
