No ACDRV - Possible faulty capacitor - Pls advise
  • IamPritesh
    • Aug 2017
    • 354
    • India
    Please refer to the image . The board came with no charging ..I have replaced the charging IC Bq25A but symptoms are same. There is no schematic or boardview for the same. If the capacitor is faulty, how do I know which value capacitor should I use. Can I use a jumper ?
    Also is ACDRV an output voltage from the Charging IC? I think it should be around 25V
    If any information is missing pls let me know.
    MB : CSL50/CSL52 LA-E791P
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: No ACDRV - Possible faulty capacitor - Pls advise
    Check second DC-in MOSFET for short between drain/source/gate, and for short to ground.
    ACDRV is indeed a volatge generated by a charge pump inside charger IC and should be around 25V (DC-in voltagr +6V).
    • IamPritesh
      • Aug 2017
      • 354
      • India
      Actually the ACFET [ MTB04N03] is short between drain and source .
      so which alternative mosfet can I use..? I have the following N channel mosfet in similar package
      MDU2657
      K03B9
      FDMS0312AS
      FDMS7698
      • piernov
        • Jan 2016
        • 4435
        • France
        Anything that has same or higher max Vds (30V), and same or higher current rating Id.
        • IamPritesh
          • Aug 2017
          • 354
          • India
          Replaced both the mosfet still unable to resolve ACDRV voltage is only 18.5 V
          • piernov
            • Jan 2016
            • 4435
            • France
            Measure exact voltage on both DC-in MOSFETs drain/source/gate.
            Measure resistance to ground after second DC-in MOSFET.
            • mcthr
              • Aug 2019
              • 25
              • Philippines
              Check current sensing resistor if its short to ground
              • Sephir0th
                • Oct 2020
                • 1260
                18.5V at ACDRV means there is still a shorted DC-IN Mosfet present. I didn't noticed any other reason so far.
                FairRepair on YouTube
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  No doubt about it. Bang on.
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
                  • chth96
                    If I replace with inferior capacitor, Is it No harm to other IC components at all?
                    by chth96
                    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                    I know that these capacitor will not last as long as nichicon capacitor...
                    12-22-2023, 04:34 AM
                  • chth96
                    How can I test non-polarized capacitor?
                    by chth96
                    I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                    I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                    And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                    I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                    06-02-2024, 07:31 PM
                  • chth96
                    Is it no harm to replace with capacitor without ripple current rating?
                    by chth96
                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                    Rubycon YK DataSheet (b...
                    04-19-2024, 05:19 AM
                  • chth96
                    Should I replace polymer capacitor?
                    by chth96
                    a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                    I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                    Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                    Is this ESR value of polymer capacitor correct?...
                    11-18-2022, 04:22 AM
