hp g62 converted to uma daax1jmb8c0
  • nabilgo
    • May 2016
    • 303
    • L.A
    but still work on amd chip any help
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • Troystain
    Help EZP2023+ updated chip database for w25q256jveq?
    by Troystain
    Hello, anyone here have updated ezp2023+ chip database in .dat file format.
    I need to add w25q256jveq chip but I do not know what data should I type.
    I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
    The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
    11-25-2024, 12:53 AM
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
