820-2850 a1286 MacBook Pro No Keyboard/trackpad
  • crazeej
    • Jan 2019
    • 32
    • germany
    Hello Guys, i have this uncommon fail of trackpad and Keyboard where:
    No Keyboard and trackpad in OS -> USB Mouse works fine!
    At Startup Press Option Key -> No Reaction!
    I noticed If i Close the Screen - Screen wont Turn Off!
    Measured around Keyboard 3v3s3 there. Pp3v42 there and smc on Off ist 3.42....
    Smc issue maybe?
    Where ist z2_boost_en coming from? OK trackpad, but which Signal activate the en Signal in the trackpad? So lost on this... Maybe eine non certified Tech can give me a hint?
    U5805:
    Pp18v5S3 0v
    Z2_boost_en 0-20mv
    Smc_lid 3.42
    Button disable : 0v pretty Sure measured a Lot of stuff.
    Thx a Lot.
  • crazeej
    • Jan 2019
    • 32
    • germany
    Re: 820-2850 a1286 MacBook Pro No Keyboard/trackpad
    Nothing? Nobody Had this issue?
    • Pedro147
      • Sep 2016
      • 168
      Maybe try external; wired keyboard ? Good luck with the rest, I am on my learner plates
      My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
      • Vliegenier04
        Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
        by Vliegenier04
        Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
        I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
        Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
        06-16-2025, 12:03 PM
      • mitchw
        MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
        by mitchw
        Hello
        I got this MacBook Pro M4 Pro to have a look at.
        It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
        Since it was liquid damaged, warranty does not apply anymore.
        Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
        The main issue was that the screen remained black.
        Anyways I cleaned the liquid damaged area, put the machine back...
        09-06-2025, 07:19 AM
      • biosdi
        MacBook Pro A1989 trackpad and keyboard not working
        by biosdi
        Hi guys.
        I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
        thanks...
        04-17-2025, 09:42 AM
      • iMuhtaseb
        A2681 Keyboard, trackpad and sleep?!
        by iMuhtaseb
        Wow it's been a while since I posted!
        This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
        A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
        It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
        Tested another locked logic board on customer's top case and it posted with keyboard and...
        05-22-2025, 09:59 AM
      • oemelectronic
        Macbook M1 820-02016 Keyboard -Trackpad stop working after a while
        by oemelectronic
        Hi friends.
        This model has a very weird fault.
        Macbook Air M1 A2337 - 820-02016
        it works for a while and after a few minutes the TRACKPAD AND KEYBOARD stops working
        I already formatted, I already changed flex and trackpad. The error continues, I tried with another keyboard and the same error happens.
        works for a while and then stops working trackpad and keyboard
        (i rebooted and it works again, after a few minutes the failure returns)
        THE BOARD LOOKS VERY CLEAN and IMPECCABLE
        09-30-2022, 08:37 PM
