problem with io chip
  • arber1232
    • 379
    • Albania
    hi everyone i have laptop 450 g3 problem with IO chip is damage . chip damage is NPCE586HA0MX CAN I CHANGE WITH NPCE388NA1DX
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: problem with io chip
    no
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • pengamat_hebat
      Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
      by pengamat_hebat
      I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
      Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
      However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
      I also tried applying 3.3V to pin 3, but it still didn't work.
      I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
      03-25-2025, 04:13 AM
    • BMCappelletti
      Asus Chromebox CN62 - wrong chip put on BIOS reader
      by BMCappelletti
      Long story short:
      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
      - gave the computer to his son a couple years later
      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
      (seems like the story was not that short)
      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
      01-08-2025, 07:27 PM
    • david04pt
      Problem finding chip "AWVAAH" on hp 15-cs003 | Board: DA0G7BMB6D0
      by david04pt
      Hello guys, I'm trying to fix this laptop hp 15-cs003, which when i removed the battery it suddenly stoped turning on and even the led, which indicates that's charging isn't turning on.
      I am trying to fix it, and i found a problem with this chip "AWVAAH", which I can't find on the internet or AliExpress, anything...
      I found some chips that look like that, but nothing equal.
      Can someone please help me find this "AWVAAH", i will show a picture of him.
      Thanks a lot for the help!...
      01-30-2024, 04:02 PM
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
