ES1-432 need to fix
  • String2016
    • Nov 2015
    • 2238
    • philippines
    ES1-432 need to fix
    +3V Present on every coil and on pu12 and pu13. before this laptop sometimes working with no issue but after not using for a day when plugged in automatically turns on fan not spins and no display. already done flashed the bios and ec
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: ES1-432 need to fix
    +3vpcu sy8286b pl3 =3.3v +3v_ld0 sy8286b pin17 3.3v
    Last edited by SMDFlea; 02-08-2020, 08:32 AM. Reason: Renamed title to match thread title
      • 21869
      Link to schematic: https://www.badcaps.net/forum/showthread.php?t=77583
      • String2016
        • Nov 2015
        • 2238
        • philippines
        anyone who encounter this problem?both 19v, 5v and 3.3v present but turns on automatically and no display on bench lab taking 0.07milliamps then goes to 0.03milliamps
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Check the voltage on PU9 PU6 pin 8 9 3/5VS Line is ok or not
          • String2016
            • Nov 2015
            • 2238
            • philippines
            @techtiger thanks for the response. PU9 PIN 8 AND 9= 5V PU6 PIN 8 AND 9 = 3.3V
            • String2016
              • Nov 2015
              • 2238
              • philippines
              Ill tried to flashed the ITE8987E chip but end up on SVOD3 ITE is not detected
              • Techtiger
                • Oct 2014
                • 1602
                • france
                whate are the missing voltages on the MB on the coils ? and check on SIO
                RSMRST
                DNBSWON
                HWPG
                EC_PWROK
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  RSMRST present
                  DNBSWON present
                  HWPG present
                  EC_PWROK present
                  I need working EC ITE8987E 128KB file please
                  • Rekoo1997
                    DELL Precision 3520 powers on automatically
                    by Rekoo1997
                    Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
                    Issue: The laptop powers on automatically after being shut down.
                    Actions Taken by Technician:
                    BIOS reflashed
                    Intel ME region cleared
                    Result: Issue still persists
                    Additional Observations:
                    Power button reads 3.3V (normal)
                    The problem occurs both when running on battery and when connected to AC adapter...
                    08-07-2025, 08:48 AM
                  • _max_
                    Hisense H60N5705 automatically switches off
                    by _max_
                    Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
                    Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
                    Power cable and HDMI cable checked.
                    No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
                    So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
                    03-07-2025, 06:14 AM
                  • dit3
                    HP ProBook 455 G7(DA0X9MMB8F0), fixed bad RAM power rail, laptop works, but now automatically turns on after AC is connected
                    by dit3
                    Hello everybody,
                    I got HP ProBook 455 G7 which originally turned on partially(fans on 100%) and hen off after 8 seconds, with AC diode flashing orange and last flash white. This behaviour stayed for a while, but before I realised that there is power delivery issue and not BIOS problem, laptop started to automatically turn on after 2 seconds when in turned off, kept power cycling. So after I fixed shorted cap and burned ferrite bead, laptop turned on fine and booted to windows.
                    Now, laptop can be turned off and it stays like that... unless you plug adapter again, which triggers...
                    01-06-2024, 04:44 PM
                  • Steradiant
                    Samsung UE40F6340 turns off automatically
                    by Steradiant
                    My Samsung UE40F6340, which I only use occasionally, has recently started turning itself off. It can take a few seconds to a few minutes before it happens. I've checked the auto sleep settings and similar options and found that none of them are enabled. I also unplugged all connected devices, but that didn't change anything. Of course, I also tried a different power outlet, which didn't help either.
                    After that, I opened the TV to see if there was any apparent defect, but found nothing. Pictures are attached. Then I disconnected the cable between the power board (right side) and the receiver...
                    05-09-2025, 05:21 AM
                  • shamaltech
                    Asus X510U Restart Automatically
                    by shamaltech
                    I have a Asus X510UN laptop came from a customer.
                    The problem of that is, it restarts randomly.
                    I tried flashing Bios,Changing ram,hdd and also reinstalling OS & drivers.
                    Any guide to diagnose this issue ?
                    Asus X510UN
                    i7-8th Gen
                    2GB Nvidia VGA...
                    02-20-2025, 09:40 AM
