dell 3521 start with 2 bip
  • nabilgo
    • May 2016
    • 303
    • L.A
    dell 3521 LA-9104P start with 2 bip i all ready changed the memory and flash new bios 1.5v present any suggestion ????
    and when i touch the pch i feel she becoming more hot and when i mesure it i found it 59 degres
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: dell 3521 start with 2 bip
    Check for DRAMRST pin 30 Memory slot
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Pin 199 also for spdvdd
      • nabilgo
        • May 2016
        • 303
        • L.A
        1.07 DRAMRST i only check it with multimaitre on pin 30
        • nabilgo
          • May 2016
          • 303
          • L.A
          voltage on 199 pin 3v is present
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Check again it should be 1.35V
            • nabilgo
              • May 2016
              • 303
              • L.A
              is that the 30 pin if yes theres no voltage on it and it shorted to the ground
              • Techtiger
                • Oct 2014
                • 1602
                • france
                no wrong pin
                • nabilgo
                  • May 2016
                  • 303
                  • L.A
                  no wrong pin
                  ok i mesur it i found 1.49
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Flash BIOS again with a working one
                    • nabilgo
                      • May 2016
                      • 303
                      • L.A
                      i all ready did twice the probleme in the pch 100%
                      • nabilgo
                        • May 2016
                        • 303
                        • L.A
                        • Techtiger
                          • Oct 2014
                          • 1602
                          • france
                          Heat the PCH slightly with good flux and see if any changes , what voltage are missing on coils?
                          Check for SYS_PWROK , did you flash both bios if so voltage on all pins 2chips
                          • nabilgo
                            • May 2016
                            • 303
                            • L.A
                            yes i flashed both of them all voltage are present pch need to be replaced because it becoming hot after turning on the laptop
                            • nabilgo
                              • May 2016
                              • 303
                              • L.A
                              no voltage is missing
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                PCH getting hot is normal. Check carefully ram slots for bad contact/corrosion.Do you have ddr3 ram slot tester card??
                                • nabilgo
                                  • May 2016
                                  • 303
                                  • L.A
                                  unfortunately i dont have it tell me wich pads i need to check because when i asked the client how he did stop he told he didnt use the laptop for 2 month and when tried to turn on he did 2 bip directly
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    Check U25 pin 17 20 22 23 26 Voltage
                                    • nabilgo
                                      • May 2016
                                      • 303
                                      • L.A
                                      thanks for your help probleme solved by changing pch
