How to make the dell laptop work on external monitor?
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi i have this
    Dell Inspiron14r-5447 i5 ZAVC0 LA-B012P REV:1.0
    I wanted to use it with a external monitor but if i used it it 8 beeps
    the screen is broken already it wont display ,
    I already remove the LCD connection but it beeps 8 times even with the LCD pluggin, trying the external same it beeps 8 times.
    and I tried a old lcd with other lapto it will display.
    How can i make it work with a external monitor
  • Borse2008
    by Borse2008
    • There’s
    07-15-2025, 04:55 AM
  • ArchangelGabriel
    Aorus 17G YD laptop, broken display, could not switch to external monitor
    by ArchangelGabriel
    Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
    11-23-2023, 03:55 AM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • Eradicatus
    Dell Latitude E5550 - Strange Internal LCD (BIOS?) Issue
    by Eradicatus
    I have a problem with my Dell Latitude E5550 laptop, in particular with its display.
    This laptop has been sat under my desk (unused) for quite a while and I wanted to reinstall Windows and use it for some ad-hoc testing.
    However, I am struggling with the display, which is playing up.
    1) When the laptop is left switched off, after switching it back on the internal LCD does not work. No images are displayed at all - no DELL logo on POST, no messages, no Windows desktop. But I can hear that Windows starts up correctly, so no issues with the rest of the system - must be...
    04-20-2022, 02:40 AM
  • Jesus Coder
    Issues Reviving Old Dell 2408WFPb Monitor
    by Jesus Coder
    I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
    06-25-2023, 02:33 PM
