Acer ES1-521-67LP Model: NX.G2KEX.025
  • indig0F10w
    • Jan 2020
    • 5
    • Croatia
    Problem: battery doesn't charge and LED1 is constantly blinking in amber color.
    Backstory: this laptop came for a battery replacement, the factory battery died after more than a year of use. I replaced it with battery received from Acer Croatia authorized service provider. They sent me a Cameron Sino CS-ACE150NB. Battery is recognized by laptop and it boots normally with it. Latest BIOS is installed. Everything works properly except battery charging.
    Laptop has original charger and I also tried with aftermarket charger. The battery doesn't charge but it depletes normally. When charger is plugged in it doesn't say "not-charging, just "plugged in". Tried uninstalling battery from device manager. This laptop also has the battery disconnect button SW2 which I also tried. No go.
    What does the constant LED1 amber blink mean?
    The schematic was posted in this thread.
    Thank you.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Acer ES1-521-67LP Model: NX.G2KEX.025
    Check the resistance to GND Battery Coil( with out power no battery inserted) if more then 500 Ohms the line is good after check all pins of battery connector with and with out battery for voltage
    • indig0F10w
      • Jan 2020
      • 5
      • Croatia
      Thank you very much for responding. Do I check on the contacts shown in linked image?
      https://imgur.com/a/sf6EiWV
      • Techtiger
        • Oct 2014
        • 1601
        • france
        check the resistance to GND PL207 PL202 PL303
        check PQ304 N Fet with out power for any short if dont know how to test go through YOUTUBE
        check the voltage on PQ305 pin 5 must be 18-20V
        may be the new battrey is not working
        • indig0F10w
          • Jan 2020
          • 5
          • Croatia
          Sorry for long time no response I was trying to get a new battery and do the tests you recommended.
          This was the 2nd battery I tried and also no charging.
          On this mainboard I cannot PL207 and PL303. Images of MBO are here.
          I couldn't figure out how to test PQ304 so I took the mainboard to a guy who knows how and he said it is not shorted.
          I will try to test PQ305 today.
          • indig0F10w
            • Jan 2020
            • 5
            • Croatia
            Better quality mainboard images:
            https://drive.google.com/file/d/1vsj...ew?usp=sharing
            https://drive.google.com/file/d/1BIR...ew?usp=sharing
            • Techtiger
              • Oct 2014
              • 1601
              • france
              Check voltage on all pins BQ24725 PU301 if you can but Since you are newcomer if the pins get short set Dead
                NVDC charger configuration...
                11-05-2024, 03:28 PM
              • DenK
                Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                by DenK
                Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                12-06-2024, 01:29 AM
                ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                Narrow VDC applications where the system power source is
                either the battery pack or the regulated output of the charger.
                This makes the max voltage to the system equal to the max
                battery voltage instead of the max adapter voltage. Operating
                at lower system voltage can improve...
                11-05-2024, 04:43 PM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • serious_electron
                Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                by serious_electron
                Hello Everyone!
                I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                06-28-2025, 02:57 PM
