Asus X455LJ need to identify the chip please help
  • String2016
    • Nov 2015
    • 2229
    • philippines
    I need to identify this chip because when i plugged the charger this chip is very hot. The board is X455LJ REV 3.1. I have attached the image of the board and chip can someone identify and help please
    Last edited by SMDFlea; 06-08-2021, 10:21 AM. Reason: added "Asus X455LJ" to thread title
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: need to identify the chip please help
    From boardview, PU8100 is the 3V/5V regulator. Could be UP1589Q, confirm with markings.
    • khaahk
      • Dec 2013
      • 757
      • Estonia
      And what is the marking on the chip?
      Most likely it is 3/5 V controller. If hot - usually means too much current drawn either from ldo or smps output. Measure resistances on outputs pin 3,8,13,14 - search for low values.
      • String2016
        • Nov 2015
        • 2229
        • philippines
        pin 3= 13.58kohms
        pin8= 2.95kohms
        pin13=2.95kohms
        pin14=14.75 then goes to 0kohms
        • Conste
          • Oct 2018
          • 235
          Look if KBC is shorted, had this problem before on a pretty similar ASUS board and KBC was dead
          • khaahk
            • Dec 2013
            • 757
            • Estonia
            Pin 14 - 5V, if i understand you correctly it is shorted.
            You need to find the short on the board. Methods are described - search.
            Boardview attached, might be helpful.
            Link to boardview - https://www.badcaps.net/forum/showthread.php?t=97317
            Link to 455LJ Rev 3.1 boardview - https://www.badcaps.net/forum/showthread.php?t=124490
            • String2016
              • Nov 2015
              • 2229
              • philippines
              @conste thanks for the info the kbc is not shorted one ceramic caps near kbc its shorted replaced it short its gone but bios and ec corrupted, Flash main and ec problem solved! thank you
              • String2016
                • Nov 2015
                • 2229
                • philippines
                @khaahk thanks for the help already solved the problem, the culprit is ceramic caps near kbc replaced it and program both main and ec now laptop working fine. thank you
                • idi_micro
                  • May 2021
                  • Indonesia
                  Hello master
                  I have the same problem, i check pin 20, it must bee 5v, drop to 3v.
                  Where is P5v En 5 goes?
                  Thanks for the help
                  • zarmo
                    • Feb 2019
                    • 4
                    • Philippines
                    Hi there.Pls i need schematic diagram x455lj
                    • mon2
                      • Dec 2019
                      • 14004
                      @zarmo, will a boardview file help ?
                      • zarmo
                        • Feb 2019
                        • 4
                        • Philippines
                        @mon2, yes, but this is my problem, all voltges are flactuate 3v5v, 1.35v, 1.0v, 0.8v ..when i plug the power to the bord the power led indicator & airplane led indicator are both together blinking continuously..when i press the power button nothing happen..i dont know witch problem come from..thanks for the reply friend
                        • mon2
                          • Dec 2019
                          • 14004
                          @zarmo,
                          1) power down and remove battery & adapter. Meter in resistance mode (ohms). Black lead to ground. Red lead on every inductor / coil you can locate on the board.
                          Checking for low resistance on each coil. It is ok to have a low resistance on the very low voltages used by the CPU / GPU components.
                          2) Post your values. This may indicate a bad cap - often are tantalum caps with a polarity mark. Such a bad cap derates over time and causes a short circuit event which leads to a high current spike for that voltage rail. The local switching IC will then deem this to be a short circuit and cause the power rail to shut off and usually leads to power cycling as you are observing.
                          • ch3nzu
                            • Jul 2021
                            • 43
                            • indonesia
                            Re: Asus X455LJ need to identify the chip please help
                            Anyone know the value of R3053? Is it a 0 ohm resistor?
                            I have problem, in pin2 i have 3.2V, but in pin1 im not getting 3.2v, its keep changing between 1.6-2.6V up and down (its happen when i just plug the power adapter).
                            When i press power button, it shown 3.2V steady in pin1.
                            • mon2
                              • Dec 2019
                              • 14004
                              See attached.
                              • ch3nzu
                                • Jul 2021
                                • 43
                                • indonesia
                                Originally posted by mon2
                                See attached.
                                thanks mon2
                                • vitinhtrikhoi
                                  • Jan 2023
                                  • Vietnam
                                  See attached.
                                  Could you share your boardview file, my boardview file does not show any info of components.
                                  Thank you.
                                    • 20665
                                    Thank you.
                                    The link to the available boardviews are at post #6 .The picture at post #15 shows at the top left that its a X455LD Rev 2.1 boardview.Use the forum search and see if its been posted.
