asus x455lj rev 2.1 cannot power on
  • vampy999
    • Sep 2019
    • 110
    • malaysia
    Hi everyone,
    This board (ASUS x455lj)cannot power on once powered off. But can power on when i short Q3204 pin 3 to ground. Anyone can tell me what problem is this?
  • PantherDave
    by PantherDave
    Hi all!
    I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
    05-29-2024, 02:01 PM
  • ShadowAi
    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
    by ShadowAi
    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
    03-15-2024, 10:46 AM
  • meraklinetx
    Asus Z97-a power cycle, no boot no cpu voltage
    by meraklinetx
    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
    05-10-2023, 06:08 AM
  • conghuyms
    Request for Help – ASUS G531GW Rev 1.6 – No Power On
    by conghuyms
    I need your support with an ASUS G531GW Rev 1.6 laptop.
    When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
    Here’s what I’ve checked so far:
    • Motherboard has been removed for inspection.
    • 3V and 5V always-on rails are present (3V/5V_ALW).
    • 1.8V and 1.09V at the PCH are present.
    • I don’t have the boardview/schematic, so troubleshooting is limited.
    • I tried checking the power button signal from the
    07-20-2025, 09:14 PM
  • Duranitron
    Asus x512dk rev 2.1 power on problem
    by Duranitron
    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
    11-26-2024, 10:22 PM
