Asus GL753VE - No video/POST
  • PTCS
    • Dec 2011
    • 15
    • United States of America
    I am looking at an Asus GL753VE laptop that will not turn on (confirmed defective motherboard). The charge light stays on while plugged into power adapter. Laptop power light comes on with press of power button... stays on until when/if power button is held down for 10 seconds. No other signs of life.
    I do not have a schematic for this board.
    I have not found any visible signs of damage... water/liquid, heat, or otherwise.
    There are 19v, ~5.5v, and ~3.3v at many various places in the board.
    The chipset warms up a little when the laptop is powered up.
    Can anybody offer any insight as to what I can look for next?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus GL753VE - No video/POST
    Mb number? Check the voltage on all big gray coils as you power up take a pic mark the voltages and post
    • PTCS
      • Dec 2011
      • 15
      I will follow though with your request when I get a chance... possibly later this evening. But in the meantime, I did realize today that I don't believe the first mosfet (after the power input) is getting turned on.
      • PTCS
        • Dec 2011
        • 15
        Asus GL753VE
        Board part number 60NB0DN0 - MB1500
        • PTCS
          • Dec 2011
          • 15
          Earlier when I said there was "no visible damage"... well please strike that from the record. I found this burned area today. It's directly on the other side of the board from the right hand side of this LCD connector.
          • jasko_jacker
            • Oct 2014
            • 1140
            • italy
            The burnt component is an inductance , remove it and check if there is a short
            on both pads. I don't know where is connected because the nets are under the
            lcd connector.
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • ShadowAi
              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
              by ShadowAi
              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
              03-15-2024, 10:46 AM
            • leonada2008
              ASUS TUF3 video memory power supply failure
              by leonada2008
              ASUS TUF3 3 fan version, under high load, image loss, black screen, flash back, large area of video memory reports unknow error, suspected to be video memory power supply failure, now request a boardview, thank you
              04-23-2025, 01:59 AM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
