ASUS UX303LN rev2 +3VDSW partial short?
  • brew99
    • Jan 2019
    • 132
    This board will no post and has no charger or power on LEDs when AC adapter plugged in. Most coils measure fine except +3VDSW which in diode mode is 0.076V. This doesn't sound like a typical short for this rail to me, so wondering what might be causing it. I've injected 3V on the rail and the only thing that heats up somewhat is the small die (PCH?). Does that sound like its done for?
    I also have the +1.35V rail measuring 0.16V in diode mode. Does that sound right for DRAM rail or is that also partially shorted?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ASUS UX303LN rev2 +3VDSW partial short?
    Measure the resistance in ohms mode
    • brew99
      • Jan 2019
      • 132
      40 ohms on +3vADSW
      130ohms on +1.35VO
      • reparetech
        Lenovo NM-C421 partial RTCVCC short
        by reparetech
        Hi, I seem to have a partial short on the VCC3SW circuit coming from RTCVCC.
        • VCC3SW initially measures about 1.1V.
        • RTCVCC to ground measures approximately 9 ohms, but it does seem to fluctuate as I have measured it at 2 ohms.
        • There is no apparent water damage (or any other damage) on the board.
        • Removing PD0001 disconnects RTCVCC from VCC3SW and VCC3SW is back to 3.3V.
        • R1301 measures about 1M measured directly on board
        • C1608 and C1609 have been removed.
        • There is no CMOS battery connected.
        • C2001 is a no stuff.
        11-11-2022, 07:04 PM
      • TheNuclearOption
        Macbook Pro (820-2773) 20 ohm partial short on the pp3v8 power rail after water damage
        by TheNuclearOption
        water damage to the left speaker channel circuit caused an internal board short that has been carved out and damage to various capacitors. I removed both chips ur630 and ur600 both were burnt. Im not sure how to track down this partial short. Any suggestions would be greatly appreciated.
        The fuse is blown on ppbus and im getting 12.24v to the ppvbatt side of the fuse
        03-11-2024, 06:16 PM
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • iMuhtaseb
        820-02098 M1 Pro 14" PPBUS partial short
        by iMuhtaseb
        board came with no signs of life whatsoever, taking only 5V.. measured PPBUS and it was partially shorted (I kinda know this is not an easy one when it's a partial short) around 9 ohms in resistance and 0.012 in diode mode.
        Injected 2 volts since 1v was not enough and my initial suspicion was correct it was the haunted TPS62180.. and on board it looked little discolored to my on the visual inspection..
        Removed and replaced successfully now left ports take 20V for 2 seconds then switch to 5v and cycle.. on the right side it does not even power on the amp meter.....
        01-04-2024, 01:53 AM
      • Stephen
        MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
        by Stephen
        I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
        02-06-2025, 12:03 PM
