DELL N4030 No 3.3v
  • String2016
    • Nov 2015
    • 2238
    • philippines
    DELL N4030 No 3.3v
    I need help on this please DELL N4030 DJ1 CP Discrete 09259-2 48.4EK01.021.The problem is 19v is present but there is no 3.3v on regulator ic PU4603, But on the power switch it has 2.9v. anyone can help me on this please
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: DELL N4030 No 3.3v
    All of the pins are ov except pin 13=18v and pin 8=3v fluctuating and pin 8 is beeping to ground
    • piernov
      • Jan 2016
      • 4439
      • France
      What is the exact resistance to ground on pin 8?
      • String2016
        • Nov 2015
        • 2238
        • philippines
        red on the ground and black on pin 8 1.0k and black on the ground and red on pin 8 0.18k
        • peste
          • 13630
          • ROMANIA
          pin 16 PU4603 = 0v, missing + PWR_SRC ...
          • String2016
            • Nov 2015
            • 2238
            • philippines
            yes pu16 have no voltage also
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
              Dell Inspiron N4030 Laptop Schematic
              09259-1 Arsenal DJ1 DIS...
              10-31-2024, 04:09 AM
              Dell Inspiron N4030 Laptop Boardview
              Dell Inspiron N4030 Laptop Boardview...
              10-29-2024, 04:40 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
