Charging a Dell D630 from another source
  • leotron
    • Apr 2019
    • 29
    • Offworld
    Like the title explain, I have an old Dell D630 laying around, sadly I don't have the original charger and the generic ones doesn't work because they function under the one wire protocol iirc.
    I was wondering if I could charge it from another laptop, I have a Thinkpad , an old Acer 150, a pair of netbooks, etc.
    Luckily I found the schematic of the said battery, but I don't think that conecting the wires randomly would be a good start.
    Thanks for your time.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Thomasraud
    Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
    by Thomasraud
    i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
    QUOTED
    -It works on charger (without battery connected-only charger)
    -It works on battery (without charger connected-only battery)
    -& it also works when plugged in battery & charger, but it's not charging the battery
    //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
    and..
    QUOTE
    The IC cannot maintain the input current level
    06-28-2022, 06:47 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • Robocop
    Dell G3 3579 (LA-F611P) not charging
    by Robocop
    Hey guys,
    I've seen several questions about this exact issue, but I've never found the fix, so I would appreciate if we can start over the whole debugging process again from start to finish, for my specific issue.
    In the BIOS setup, (see pic) the AC adapter is detected with the correct power rating, the battery is stated as charging (when plugged in, of course), and the battery health is stated as "Excellent" (as expected, since this is a brand new battery purchased a couple of weeks ago). However, the battery never charges (the percentage never increases)....
    06-25-2024, 08:15 PM
  • 0x0null
    Dell Latitude 5530 not properly charging
    by 0x0null
    This Dell Latitude 5530 will not charge when turned off. when turned on and in bios it will charge properly and the adapter wattage is shown.
    I noticed that when in bios if the charger is unplugged the bios still reports the laptop as charging and the charging light in front of the laptop stays on
    When charging, PL4401 has a stable voltage of 12.8V however when plugged in but not charging the voltage alternates between 4v and 12v on PL4401
    Please help
    12-16-2024, 11:06 AM
