a1466 820-00165 power on
  • guruji
    • Oct 2012
    • 122
    • India
    hello
    i had a a1466 with a weird problem the laptop powers on without macos as many times you want but the moment i get into the login page and i login into the macos and then shutdown ,after shutdown it does not power on ,it can only power on when i connect the adapter or disconnect the battery and reconnect it then it works the battery is perfect no issues with it also charging is perfect.if i dont login it can power on /off innumerable times on battery.i have tried a new os also another ssd.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: a1466 820-00165 power on
    Try another battery. Be aware that most random batteries on eBay/Aliexpress are garbage and may exhibit the same problem.
    • guruji
      • Oct 2012
      • 122
      • India
      changed battery with another laptop battery is fine
      • piernov
        • Jan 2016
        • 4439
        • France
        Check charging circuit current sensing (resistance between pins 17/18 and between pins 27/28 of U7100)
        • guruji
          • Oct 2012
          • 122
          • India
          hi again
          yes all theat is also fine as the battery charges well so i dont think any issues with the battery circuit ,but i notice something my camera does not work i get message camera not connected the chip is bcm15700a2.something to do with power management where the discharge signal. it is only the second time when i go to power on battery it does not.
          • guruji
            • Oct 2012
            • 122
            • India
            okay so i reballed the camera memory now camera is fine but i still have no power on with battery the second boot battery is fine i changed the smc also battery is charging well .Which signals i need to check for powering on from battery
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              by sam_sam_sam
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
