nm-a273 / lenovo z 50/70 No post
  • crea2k
    • Oct 2016
    • 32
    • United Kingdom
    I've got an nm-a273 / lenovo z 50/70 here and the centre pin of the charger touched positive and blew up the super io. Iv replaced the charge port and the super io and the bios chips. Bios and super io were programmed by the supplier for this board.
    The board now turns on and the leds come on when the power button is pressed, but the hard drive doesn't spin up and Lcd does not power on and fan doesn't spin.
    I have tested voltages and +5valw is present and so is +valw , but +5vs and +3vs isn't present.
    I checked the mosfets q23 and q24 and power is coming into one side but not out of the other.
    I have checked the gate on both and there is zero volts on the gate on both.
    The gate of the 5vs mosfet is connected to +20vsb, this is zero volts, but if I check pj201 +20vsb is present, it's just not at the gate of q23 and q24
    pu301
    1-20.17
    2-20.17
    3-0
    4-0.104
    5-0.004
    6-2.633
    7-0.005
    8-3.385
    9-3.384
    10-0.807
    11-1.214
    12-1.862
    13-1.862
    14-0
    15-0
    16-6.00
    17-5.79
    18-1.856
    19-1.8
    20-20.17
    21-
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: nm-a273 / lenovo z 50/70 No post
    SUSP is missing that’s why GATE Is not operating check the voltage on PQ25 26 Gate if not trace it back up to SIO pin 124
    • crea2k
      • Oct 2016
      • 32
      • United Kingdom
      Thanks, il try that, what should output of pq202 be ?, as on pin 1 I have 20v.
      • Techtiger
        • Oct 2014
        • 1602
        • france
        If it’s from dc jack +19V if it’s from +B battery approximately 13-14V
        • crea2k
          • Oct 2016
          • 32
          • United Kingdom
          Ok so Iv tested pq202 and suspend seems to be present. On the gate I have 3.6v and pin 1 and 3 is 20v. Its just the 20v isht getting to the gate of the 5vs mosfet. Shall I trace a wire from the output of pq202 to the gate of the Q23 ?.
          • Techtiger
            • Oct 2014
            • 1602
            • france
            That’s not SUSP PQ202 +B line is connected with 2 resisters 100k 22k PQ202 GATE voltage come from this voltage Divider
            • Techtiger
              • Oct 2014
              • 1602
              • france
              you have not responded to POST 2
              "check the voltage on PQ25 26 Gate if not trace it back up to SIO pin 124"
              test the Voltage SIO pin 93 2 128 14 72 109 18 21
              • crea2k
                • Oct 2016
                • 32
                • United Kingdom
                Q25 has a hole in it, so il order a replacement and again then.
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  Upload a pic
                  • crea2k
                    • Oct 2016
                    • 32
                    • United Kingdom
                    https://www.badcaps.net/forum/attach...1&d=1576086162
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      Clean it up with Alcool Isopropylique and remove Q25
                      • crea2k
                        • Oct 2016
                        • 32
                        • United Kingdom
                        Ok so Iv replaced q25 and pq202. Now I have 20v on two legs of pq202 and the 3.6 on the other, this seems to be working as at R149 I am getting 20v on pin 1 and 1.685v on pin 2. This means that the gate of q25 is getting 1.685v. On the output of q25 I’m getting 1.6v.
                        On the gate of q23 I’m getting 0.9v , which means the output is only 1.5v, with the input being 5v
                        • crea2k
                          • Oct 2016
                          • 32
                          • United Kingdom
                          1.68v seems rather low, is it supposed to be like that the other side of that first resistor ?.
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            SUSP suppose to be approximately 3.3V From SIO to Gate of Q25 the Voltage you are getting is low, on working conditions when SUSP hits Q25 it will pull up +20V from R149
                            To Gate of Q23
                            • crea2k
                              • Oct 2016
                              • 32
                              • United Kingdom
                              I tested the resister and it is within spec, so wasn't sure why the voltage was so low ?, as I have changed the mosfet itself.
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                What voltage on the pin 124 SIO before power up and after power
                                • crea2k
                                  • Oct 2016
                                  • 32
                                  • United Kingdom
                                  124 - 0v when on or off
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    So you confirm test the voltage on pin 124 as you press the power btw ?
                                    • asliyucegsm
                                      • Jun 2011
                                      • 350
                                      • Turkiye
                                      Hello friend, did you solve this problem? I have the same problem. I cannot get susp and susp#. It does not draw any current. There are 3volts and 5volts. When I press the power button, the motherboard LED turns on, but it does not draw current.
                                      • MORETTIGIAN
                                        Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                        by MORETTIGIAN
                                        Title:
                                        Description:
                                        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                        I did not notice it detaching, so I am unsure of its original location on the PCB.
                                        Procedure performed:
                                        - Removed backplate
                                        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                        - Reapplied thermal compound
                                        - Reassembled card
                                        Observed behavior after reassembly:
                                        - GPU powers on and operates normally under...
                                        09-18-2025, 12:14 PM
                                      • ferah831208
                                        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                        by ferah831208
                                        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                        03-18-2025, 01:18 AM
                                      • air_chair256
                                        Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
                                        by air_chair256
                                        I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
                                        Tried to reball RAM 1,2,3,4
                                        Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
                                        02-13-2024, 06:00 AM
                                      • lapfix
                                        Lenovo Air 15ITL NM-D211 missing RSMRST !
                                        by lapfix
                                        Lenovo Air 15ITL.
                                        NM-D211
                                        This laptop won't power on , when power supply is on it takes 0.001 , button trigger on it becomes after a couple of seconds 0.061 amp..and nothing
                                        No heating (Of COURSE) , no short to GNd at all coils present , 3/5 valw is present , 3/5 vl present.
                                        With the power plane , at state 4 +1.8VALW and +3ALW_PCH must be present but no one due to enable signal is missing .
                                        when button trigger on , 3v dow to zero than 3v , the super io send BTN_OUT#_R to pch but no rsmrst ..0v.
                                        i follow his line , no short .
                                        10-21-2025, 05:53 AM
                                      • Paul20
                                        Swap Super I/O Lenovo Ideapad
                                        by Paul20
                                        Hi, I would like some advice.
                                        I have two motherboards, one with a dedicated GPU and the super I/O with obvious burn marks on it, and another working motherboard without a dedicated GPU.
                                        My question is: can I swap the super I/O from the motharboard without dedicated GPU to the one with dedicated GPU? Will it work anyway or is that super I/O taken from the motherboard without GPU only good on motherboards without dedicated GPU?
                                        The motherboards are exactly identical even in terms of versions...the only difference concerns the dedicated GPU in one and not in the other.​
                                        11-27-2023, 10:47 AM
