rt809h programming it8586 error
  • ferah831208
    • Aug 2019
    • 65
    • Cuba
    i've been stucked several weeks trying to flash an it8586 from lenovo using rt809h, i've done intensive search over the internet and no results, i have the it8xxx interface adaptor and cables, i tried with it8586 directly sokdered in adaptor, i got it from a different motherboard to the one i was going to use, first time i read it succesfully 3 or 4 times only for testing, i wrote the new kbc firmware for nm-a181 and verified ok and then the trouble begun. everytime i read the chip is not recognized, i tried many times, unplugged programmer restar windows,updated rt809h with latest version december 2019, thought maybe chip got broken, but i soldered it in the motherboard, and i got video and boot perfect, i turned off laptop unplugged it, and now everytime i put ac adaptor it starts on and off several times and i have backlight on and off in screen,it seems like a kbc fault, i then used the adaptor in motherboard with the flex cable anf everytime i get ISP error loop and finally error, maybe the chip is faulty??? but had nearly the same problem with it8987 in a different motherboard, i'm stucked,maybe rt809h has issues with ite series. i got the it8xxx adaptor and mapped all pins and connections, if somebody is interested i have it, no resistors or capacitors used,only pin to pin connections, some vcc pins to ite are separated but if u measure in the moment is reading or writing 3v are OK on all vcc pins of IT, i don't know what else to do, any ideas???
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: rt809h programming it8586 error
    do you use a microscope?
    You checked the solders of the pins one by one to check short or disconnection ?
      • 21936
      Read page 58 in the instruction manual .
      • ferah831208
        • Aug 2019
        • 65
        • Cuba
        jasko_jacker all is perfect, i measured pin by pin in ITE to connector, don't know what's going on
        • ferah831208
          • Aug 2019
          • 65
          • Cuba
          smdflea do u have by any chance it8586 datahseet?i read the manual 20 times, the only thing it mentions about entering isp mode hase to do with pin100 #ecmute, i understand accesibg it soldered in motherboard maybe i have to gly that pin to ground, but soldered directly in it8xxx adaptor that pin goes to ground in the pcb layout and it didn't work also, anyway i'm teying now with a working motherboard accesibg chip online, i'll try to fly ecmute to ground,i'll post result, thanks👍
          • ferah831208
            • Aug 2019
            • 65
            • Cuba
            same result, all pins configuration are OK, i checked it again directly fron programmer ñins mapped to it8586,flied 100 ecmute pin to ground,sometimes i get wait for the chip enter isp status, read tineout, other id verification error, if i press read before plugging the laptop like says in the manual i get a window error failed to enter isp status, please make sure the motherboard made suplies voltages, i plug it automatically the window closes and again waiting for chip enter isp status, i'm doing this with a working motherboard,to be 100 sure IT is working, any new ideas???������
            • stylius
              RT809H ISP programming for laptop bios.
              by stylius
              Hello. I need some info. I have very good programer CHIPProg-481, fast and good programmer, but now I want read and modifi laptop bios dump without desoldering it. So want buy new programmer like RT809H for ISP programming for laptop bios. It is good for isp programing? or you recoment other?
              02-17-2023, 04:44 AM
              HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
              This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
              09-06-2024, 08:50 AM
            • ajbernasko
              by ajbernasko
              Hello, Please I need a general knowledge in ISP programming for the RT809h. For instance an 8 pin bios chip, which one is the DO, CLK, CMD VCCQ of which I know pin 4 GND and PIN 8 is the VCC.
              1.
              2.
              3.
              4. GND
              5.
              6.
              7.
              8. VCC
              Please help me. Thank you
              12-02-2022, 07:45 AM
            • araxnido
              Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
              by araxnido
              Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
              When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
              06-10-2025, 09:26 PM
            • Simonc123
              CH341A bios chip wont fit 1.8v adaptor holder
              by Simonc123
              Hi guys, I need a bit of help. I use a CH341A programmer, which is fine for 3.3v old-style bios chips. I need to reprogram some 1.8v chips, which are QFN type chips. I have the 1.8v adaptor for that slots onto the programmer, which does step the voltage down to 1.8v, but as you can see in the picture added, it doesn't fit in the IC holder.
              Please see the 4th picture that shows what looks like what should work for the QFN IC (highlighted in red). The issue is that the 8 pads on the programmer are too long and short out the IC. Is it a case of putting kapton tape over the center ground...
              03-09-2025, 08:54 AM
